1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | what kind of fasteners are use to hold my 55.1 sun visor in place. I want to remove to install a head liner but don't know what to use. there are three pointed studs.do they twist out? screw out? drill out? thank you , brian | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Do you have pictures? My 52, and all I've seen right up o my son's 81 have three philips screws.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Those three pointed-studs might be helpful if you have a head liner that does not have holes in it for the visor/visors attachment screws.
You can position the head liner into position and press it upwards towards the pins - remove the headliner, and then drill the holes into the headliner, and then locate/cut/drill the hole you have to make for the visor spring/mechanism. | | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 |
| | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | my teenage daughter just set up some pictures. lets add computers to the list of things I don't know anything about (right under old Chevrolet trucks) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | NIce photos by your daughter: photo 1 photo 2 Are the "spring nuts" holding the pins in place? If yes, can you pry off the "nuts? They are not original. | | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | what are spring nuts? i'm going out side to see if i'm missing something .I will see if I can get a picture of the back | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If they are not spring nuts, maybe someone else will try to discern/guess what they are.
You might have to break/cut-off the "posts/pegs", if you cannot turn/pry-off the "nuts"?
| | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | I put the phone (camera) back there and discovered that they're just weird screws. then I used a vice grip to remove them. i'll probably use them as you suggested to locate the new holes in the new headliner. thanks to all that replied, brian. p.s. now that I have photo sharing(thanks to my daughter) i'll get some pictures up. it's been over five years and I have a ton of pictures | | |
