9 members (JW51, Wickedbass, 50Chevy3100, 59 fleet, msmall, 68ironhead, Shardean, DannyW, Eisenholtz), 46 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#1208020 03/11/2017 7:17 PM
6 Online: Content
what kind of fasteners are use to hold my 55.1 sun visor in place. I want to remove to install a head liner but don't know what to use. there are three pointed studs.do they twist out? screw out? drill out? thank you , brian
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
Do you have pictures? My 52, and all I've seen right up o my son's 81 have three philips screws.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
66flea #1208144 03/12/2017 12:38 PM
I have a couple NOS RH sun visors for AD's they are Phillips screws.
https://www.flickr.com/photos/advance-design_parts_co/12258396864/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/24630422886/in/album-72157631868452754/
As you can see on the install instructions for the GMC visor (on a box flap), it calls out the self-tapping screws.
66flea #1208145 03/12/2017 12:45 PM
Those three pointed-studs might be helpful if you have a head liner that does not have holes in it for the visor/visors attachment screws.
You can position the head liner into position and press it upwards towards the pins - remove the headliner, and then drill the holes into the headliner, and then locate/cut/drill the hole you have to make for the visor spring/mechanism.
6 Online: Content
https://pix.sfly.com/Qq2YCD pictures of fasteners
6 Online: Content
my teenage daughter just set up some pictures. lets add computers to the list of things I don't know anything about (right under old Chevrolet trucks)
NIce photos by your daughter:
photo 1
photo 2
Are the "spring nuts" holding the pins in place?
If yes, can you pry off the "nuts?
They are not original.
6 Online: Content
what are spring nuts? i'm going out side to see if i'm missing something .I will see if I can get a picture of the back
If they are not spring nuts, maybe someone else will try to discern/guess what they are.
You might have to break/cut-off the "posts/pegs", if you cannot turn/pry-off the "nuts"?
6 Online: Content
I put the phone (camera) back there and discovered that they're just weird screws. then I used a vice grip to remove them. i'll probably use them as you suggested to locate the new holes in the new headliner. thanks to all that replied, brian. p.s. now that I have photo sharing(thanks to my daughter) i'll get some pictures up. it's been over five years and I have a ton of pictures
Moderated by  ndkid275, Phak1
