4 members (gswbbc, 32Fordpuchoptop, dwreills, Otto Skorzeny), 77 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#1207623 03/09/2017 3:14 PM
I am putting a 350 v8 from a 72 c10 into my 56 3100. The fuel pump has a return line but the gas tank does not. What can I do with the return line from the pump?
56trucknut #1207632 03/09/2017 3:56 PM
Most would just block off the return line. I would plumb it back to the tank as far as I could and "T" it back into the fuel line coming from the tank. This will circulate fuel through the lines and hopefully help with any future vapor lock problems. Use a line smaller then the main line for your return line.
If you pull the sender out of the tank, you may find there is room to add a line. A drill and good solder iron would be about all you need tool wise to make it work. The silver ( in color ) fuel line solders really good due to the coating on it. If you go this way, make the line into the tank long enough to reach 1/2 way down into the tank.
56trucknut #1207649 03/09/2017 6:17 PM
So I could tee it back to the inlet line and be done? Not sure the sender has enough room to add another line. Really small.
56trucknut #1207731 03/10/2017 2:41 AM
Does the tank have a drain hole in that particular model?
If so you could access that for the feed line to the fuel pump (just like a 47-53 AD), and run the return line back through the line on the sending unit.
Carl
56trucknut #1207768 03/10/2017 1:12 PM
Just buy another pump that doesn't have the return line. We are only looking at two bolts and about 5 minutes of time.
Tommy
59 apache 1/2t
261 short stepside
56trucknut #1207822 03/10/2017 6:12 PM
no drain hole on the tank. Replacing the pump would be the best if I hadn't had to put a new one on to get the motor running before I put it in the truck.
56trucknut #1211423 04/03/2017 2:48 PM
BnJ Offline
Hey 56TN,
I would keep the installation clean.....put a pump that doesn't have the return ($25) install it and don't worry about it every again.
my 2 cents,
