| | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | I am putting a 350 v8 from a 72 c10 into my 56 3100. The fuel pump has a return line but the gas tank does not. What can I do with the return line from the pump? | | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | Most would just block off the return line. I would plumb it back to the tank as far as I could and "T" it back into the fuel line coming from the tank. This will circulate fuel through the lines and hopefully help with any future vapor lock problems. Use a line smaller then the main line for your return line.
If you pull the sender out of the tank, you may find there is room to add a line. A drill and good solder iron would be about all you need tool wise to make it work. The silver ( in color ) fuel line solders really good due to the coating on it. If you go this way, make the line into the tank long enough to reach 1/2 way down into the tank. | | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | So I could tee it back to the inlet line and be done? Not sure the sender has enough room to add another line. Really small. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Does the tank have a drain hole in that particular model? If so you could access that for the feed line to the fuel pump (just like a 47-53 AD), and run the return line back through the line on the sending unit. Carl
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Just buy another pump that doesn't have the return line. We are only looking at two bolts and about 5 minutes of time.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | no drain hole on the tank. Replacing the pump would be the best if I hadn't had to put a new one on to get the motor running before I put it in the truck. | | | | | Joined: Jul 2015 Posts: 10 New Guy | | New Guy Joined: Jul 2015 Posts: 10 | Hey 56TN, I would keep the installation clean.....put a pump that doesn't have the return ($25) install it and don't worry about it every again. my 2 cents, Bill
