5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#1207368 03/07/2017 5:51 PM
I would love to put a V8 in my 1960 stepside. It has a 235 and the original 4 speed tranny. I have seen what I need to do for the motor mounts. The issue I am having... I want to keep my 4 speed! I love the way it shifts! Do I have to change that out? Or is there a bell housing that will let me use it?
So it sounds like I can get another bell housing to make this work. I just love my 4 speed. Thanks for the info. And if anyone else knows of solutions please reply
sbc bellhousings were cast iron from 63 -67 i believe in the truck. to make your swap simple try and locate a 283 bellhousing for 60-62 as it has the passenger side hydraulic clutch setup as your 235 and the 283 horseshoe type front engine mount. you can still find them out there. with those items it will be a bolt in scenario
ron
Here is what I bought for my 1960 V8 Conversion (to keep my awesome 4 speed). I found the motor mounts on ebay and the bell housing on craigslist. The link to the pictures below. I thought I already posted this... It may be against the rules, or I may have not hit the submit button. I just want to make sure I got the correct stuff. http://imgur.com/a/uU7ub
Last edited by baldeagle; 03/11/2017 1:52 AM. Reason: Removed the image. We do not allow direct posting of images to the Forums.
RJ Offline
That is the correct Bell housing, you should be able to reuse your slave cyl too.
sweet thank you! Is that the correct motor mounts? They are pictured towards the end
Please review picture policy before the server explodes. I will to in case i missed a memo. In the meantime please put the pix on 3rd party site.
~ HB
1962 Chevrolet C10
1962 Suburban
yeah... They were being loaded from IMGUR.com They werent pulling form your site. There is no way they were bogging down your server. I appreciate all the help... Ill move on to a different forum for help.
RJ Offline
i didn't see the motor mount.
