| | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 6 New Guy | | New Guy Joined: Jan 2007 Posts: 6 | | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | An alignment shop,might try napa.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | There are dozens of them on Ebay, cheap. Search "front axle caster shim". Don't let the resto-ripoff guys put the vacuum cleaner in your pocket! Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You can get them direct from the manufacturer. I got mine from Ingalls. http://www.ingallseng.com/leaf-spring-wedges/You will want to consider putting new center pins in your springs while you're at it.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 6 New Guy | | New Guy Joined: Jan 2007 Posts: 6 | Thank You for all the help got it done yesterday. | | |
