4 members (fonz8261, 52Carl, frogfarmer, Bill Hanlon), 126 guests, and 2 robots.
Topics128,177
Posts1,057,060
Members48,460
I'm looking for how your fog lights are mounted specifically on AD trucks. I know there are a variety of mounts used so I wanted to get some ideas. Thanks.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Presumably, you are referring to 1947-53 A-D Chevrolet trucks?
1954-55st mount differently.
Most likely ND GMCs mount like the A-D Chevrolet trucks, except maybe in 54/55st?
Unity Lights on their brackets
Front end
Front end 2
I found these Unity fogs for sale on the HAMB for cheap. The brackets came with them. I bought some chrome bolts, along with some washers (visible in the first pic) and nuts. I drilled an appropriate sized hole in the front splash pan. I used a small circle of gasket paper to prevent metal to metal rubbing between the bracket and the splash pan, and put the washer, lock washer, and nut below. They are really stable. I ended up having to paint the brackets and the cast bases of the lights because they weren't holding up to being in the weather. I used a lighted Unity under-dash switch I found on eBay, with a parts store horn relay for power. Bulbs are amber 12v GE bulbs I found on Amazon.
(The pics were also in a recent post in General.)
I'm not sure if mine is original equipment (I doubt it). The bracket grabs the bumper support and was there when I bought my '48. I got the light case (with burned out 6-volt light) at a swap meet. It connects to the bracket via a ball and socket joint. When I went to 12 volts, I found a NAPA #4412A fits perfectly.
Fog Light Bracket
Fog Light On
Fog Light Pattern
Turns out my copy of "Chevrolet Accessories for 1948" shows no fog light fixture or replacement bulbs. Maybe they were all aftermarket with various designs.
Tim, that's correct assumption.
Eric and Wally, thanks for those...they really help. I just picked up a pair of Unity H1 fogs but still need to get some brackets.
Allan
1951 GMC 1/2-ton
Ex Hall Monitor
Ex Hall Monitor
While a tad shorter those are quite similar to late '30s brackets. <CLICK>
Allan.
Do a Google search on vintage fog light brackets.
Harold[u][/u]
Harold
Thanks Harold...quite a bit out there.
Allan
1951 GMC 1/2-ton
