6 members (gswbbc, tonyt, Otto Skorzeny, baldeagle, 55shaker, DES57), 89 guests, and 3 robots.
Topics128,040
Posts1,055,474
Members48,424
#1203366 02/07/2017 10:11 PM
I am using Jim Carters Turn Signal Switch (EL13312).
All connections check out and the unit works fine.
I have two 6 Volt Flasher Units:
1 0riginal with truck
1 New Heavy Duty
Original unit has 6.5 OHMS between Post X & L
New unit has 12.6 OHMS between Post X & L
Voltage @ Bulb sockets using Old Flasher is 6.13 Volts
Voltage @ Bulb sockets using New Flasher is 3.00 Volts
With this voltage reduction, bulb is very dim.
Indicator Lights on Turn Signal Switch do not work using Old flasher.
Indicator Lights on Turn Signal Switch do work using New flasher.[/u][u]
Any suggestions?
Harold
Harold
Harold46 #1203380 02/08/2017 1:08 AM
Simple test...switch the flasher units. If the problem follows the old flasher, then replace. If it does not, we will have to dig deeper.
Harold46 #1203395 02/08/2017 2:47 AM
I had trouble with flashers too. As I recall I finally ordered a 6 volt flasher at Napa and it was twice the price of other ones. It worked correctly but does change speed a little as it heats up. I did add flashers to the front marker lights above the head lights. I think there are many crap electrical parts being produced.
Harold46 #1203396 02/08/2017 2:48 AM
The flasher units have been switched. That is how I got the results shown above.
Harold
Harold
Harold46 #1203441 02/08/2017 12:28 PM
Do you have the two wire can or the three wire can. If three wire, power to it he interior lamps is provided by pin "P" on the can.
I just checked your switch part number and it does require the three prong can. You are using the three prong can, correct?
In the last several months I purchased two new 6 volt positive ground flasher cans. One didn't work. Found out the diode was installed backward.
Harold46 #1203451 02/08/2017 2:14 PM
Yes, it is a 3 wire flasher.
I guess I will buy another one & see if anything changes.
Harold
Harold
Harold46 #1203468 02/08/2017 4:43 PM
Harold, my comments from this thread: https://www.stovebolt.com/ubbthread..._Volt_Flasher_Unit_Info.html#Post1151612
I used a 535 flasher from NAPA (made in China), the flashers were fast, like a bulb was out...not the case though. Also the flasher did not make a perceptible clicking noise even though it is billed as a thermal unit and not one of the newer generation electronic flasher units.
I found a NOS Tung Sol 6V 535 flasher made in the USA on ebay and picked it up for around $15 delivered.
Good news, the flashers now flash at a reasonable rate and its easy to hear the good old fashion Click-a Click-a of old.
So, my advise is to consider something other than the NAPA 535 for your 6 volt flasher needs.
Added in edit; found a couple on Ebay best price is this one, http://www.ebay.com/itm/VINTAGE-TUNG-SOL-HEAVY-DUTY-NO-535-6V-FLASHER-NOS-F66-/302218307974?hash=item465d9d6986:g:oT8AAOSwa~BYa~1N
RonR
1970 340 Duster
1964 CJ5
Harold46 #1203487 02/08/2017 7:16 PM
Thanks for your comments. I must have the electronic unit. I will order the one on Ebay.
Harold
Harold
Harold46 #1203489 02/08/2017 9:14 PM
Sir Searchalot
Sir Searchalot
Keep in mind what beltfed said. There is a special terminal on the flasher for the lights inside the turn sig unit. The one's you say won't blink.
Harold46 #1203502 02/08/2017 11:32 PM
Whoa a minute. "I must have the electronic unit." Do you have LED's front and rear? Then you have an incandescent lamp as your blinker indicator? If so, that is your problem. The LEDs get a voltage pluse from the electronic can. That short pluse does not give the incandescent lamp time to heat up and glow.
Harold46 #1203507 02/09/2017 12:03 AM
No, I do not have LED's.
I do know the flasher I ordered is a Thermal unit. will see if this cures my problem.
Harold
Harold
Harold46 #1203527 02/09/2017 3:11 AM
I was not clear. I had to buy flashers from different vendors before finding one that works. They were all correct for incandescent lamps. Some just did not function correctly.
Harold46 #1205425 02/22/2017 9:16 PM
Replaced the Flasher with one made in the USA. Problem solved. Lights work as they should. Not a loud "click" but that is OK.
Harold
Harold
Harold46 #1205468 02/23/2017 3:12 AM
Sad but I had the same experience
Harold46 #1205711 02/24/2017 11:36 PM
Harold
Glad it worked out. It does seem like the "click" on mine has gotten a bit softer. Either that or my hearing has lessened another notch.
I recall amplifiers for turn signal relays, wonder if they're still available....
RonR
1970 340 Duster
1964 CJ5
