1 members (Wally / Montana),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,130 Posts1,056,720 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Are the original master cylinders the same on the 58 Viking 1 1/2 and two ton as they are on 1/2 ton? If not , does anyone know a part number or source for new or rebuilt? Also. Are the original front wheel cylinders (14 inch drums) on this Viking 60, 7-8ths bore?? That's what the sales rep at Jim carter truck parts told me. ....but the ones on my truck are larger bore so the rebuild they sent me won't fit. Wondering if mine has had heavier wheel cylinders put on at some time due to lack of availability or iff the sales rep was wrong about them being 7/8th bore. Thanks for all y'all s enlightenment and willingness to share your knowledge. Pete | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | master cylinder is not the same, I believe it is a smaller bore on the 1/2 ton. My 58 Viking 60 master cyl is a 1 1/4" bore and front wheel cylinders are 7/8 (Raybestos wk129). For some reason, I ordered the wrong wheel kits the first time, so I have 4 or 6 that are a 1/8". (Raybestos MK149). not sure what they fit though, or if they are the size you are looking for.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy txpete, the correct master cylinder bore for your truck is 1 1/4". RockAuto has Raybestos part number MC21698 $118.99 which is a new part, hope that helps. | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Mike, above you mentioned the front wheel cylinder rebuild kits for your Biking "50" were 7/8 th s and the part number for your front wheel cylinders are 7/8 (Raybestos wk129). Would that be the same on my 60 2ton? | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Mike, above you mentioned the front wheel cylinder rebuild kits for your Biking "50" were 7/8 th s and the part number for your front wheel cylinders are 7/8 (Raybestos wk129). Would that be the same on my 60 2ton? sorry, I meant Viking 60. Should be the same | | | | | Joined: Apr 2015 Posts: 113 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 113 | sorry, i don't want to hijack the thread but would that master cylinder MC21698 work on a 59 spartan 80? Gene
1959 Chevy 8500 - Spartan 80 366 BBC
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Gene_Spartan80, Unfortunately no it will not work the bore on the master cylinder for the 80 series is 1 1/2" the Wagner p/n for the assembly is FE23870. Once again unfortunately the assembly has been made of unobtainium for years, try contacting Geoff at Alretta to see if he can help, hope that helps.
