5 members (BarryP, Mike B, ShopRag, Youngin' Tut 59, klhansen), 90 guests, and 2 robots.
Topics128,139
Posts1,056,756
Members48,454
#1202551 02/01/2017 10:35 PM
anybody here have any knowledge or experience with the Rockford T 221 transfer case? Books manuals links anything? Mine did what they all do, leaked until the input shaft bearings dried up and grenaded. I know ...hard to get parts and gaskets and etc but somebody has some stuff out there. And, I am going to fix it. The center shaft for example, how does it come out?
Thanks, Greg
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
Goob #1202558 02/01/2017 11:31 PM
uh gee thanks guys. found everything to rebuild a t 221 at
Torque King 4 X 4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
Goob #1202580 02/02/2017 1:15 AM
That didn't take long. I was going to have to dig to find a reference I thought I found at some point. Document your rebuild so I can use your experience some day.
~ HB
1962 Chevrolet C10
1962 Suburban
Goob #1202605 02/02/2017 3:34 AM
Greg those are the bearings and gaskets from that place, Global transfer supply can totally rebuild 1 . There is also some nos parts on ebay
Goob #1202768 02/03/2017 7:06 PM
Along the same lines, I've got a leak on my T-221 where the speedo cable plugs into the transfer case. I've been checking around to see if anyone sells that bullet (the thing the speedo cable threads onto), but no luck. I'm guessing the seal on the bullet is shot. Any ideas where I could get one? I checked Torque King and a few other places.
Thanks, Wayne
__________________
'62 K10 Fleetside
Goob #1203000 02/05/2017 6:08 AM
Torque King 4 X 4
if you need that back cover piece, back end of input shaft. i do have one. when there is to much end play the rear bearing goes back and wears a droove thu it
ron
I managed to find everything, a back cover main drive gear gaskets shims bearings and seals
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
there is one on e bay
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
Goob #1203200 02/06/2017 8:46 PM
Sir Searchalot
Sir Searchalot
BTW: it is a Rockwell T (Timken) 221 transfer case.
