8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible),
106
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | anybody here have any knowledge or experience with the Rockford T 221 transfer case? Books manuals links anything? Mine did what they all do, leaked until the input shaft bearings dried up and grenaded. I know ...hard to get parts and gaskets and etc but somebody has some stuff out there. And, I am going to fix it. The center shaft for example, how does it come out?
Thanks, Greg
1947 M15 Studebaker 454 4x4 1949 Chevy COE In the Stovebolt GalleryMore pix of the COE1950 Harley FL 1958 GMC LCF 455 3x2bbl 1961 Chevy C60 Tilt Cab 327 1966 Chevy C60 Tilt Cab 496 1961 Chevy K10 sb 292 1974 Harley FXE 1979 Chevy K10 sb 2007 Harley Streetglide I'm not that good but I'm slow
| | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | uh gee thanks guys. found everything to rebuild a t 221 at
Torque King 4 X 4
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | That didn't take long. I was going to have to dig to find a reference I thought I found at some point. Document your rebuild so I can use your experience some day. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Greg those are the bearings and gaskets from that place, Global transfer supply can totally rebuild 1 . There is also some nos parts on ebay
| | | | | Joined: Feb 2017 Posts: 10 New Guy | | New Guy Joined: Feb 2017 Posts: 10 | Along the same lines, I've got a leak on my T-221 where the speedo cable plugs into the transfer case. I've been checking around to see if anyone sells that bullet (the thing the speedo cable threads onto), but no luck. I'm guessing the seal on the bullet is shot. Any ideas where I could get one? I checked Torque King and a few other places.
Thanks, Wayne
__________________ '62 K10 Fleetside
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | uh gee thanks guys. found everything to rebuild a t 221 at
Torque King 4 X 4 if you need that back cover piece, back end of input shaft. i do have one. when there is to much end play the rear bearing goes back and wears a droove thu it ron | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | I managed to find everything, a back cover main drive gear gaskets shims bearings and seals
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | BTW: it is a Rockwell T (Timken) 221 transfer case.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
