0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 17 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 17 | I was just thinking about all the Chevrolet trucks (6 Cylinder 235) around and what improvements you have done to your truck that has improved its drivability , performance and looks, etc etc. I would love to hear from other owners. I will start with my truck. 1954 Chevrolet Truck 3800 1 Ton Flat bed, owned since 1975 Things done to improve trucks performance 1.Fenton headers 2.Clifford intake manifold 6=8 3. Four barrel carburetor 390 4160 4.SoCal steering damper 5.Gear Vender overdrive GV-RX 6. Flowmaster mufflers (2) 40 (a little loud). 7.Convert 6 volt system to 12 volt (no need to change starter still 6V) 8.Moon electric tachometer 2 5/8 inch This truck just hums down the road, very nice. http://s1288.photobucket.com/user/richardO54/library/?sort=6&page=1
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've swapped to 8R19.5 tires and suitable wheels. And 4.10 axle gears.
Otherwise just been driving, it's happy at 50-55 but can handle the interstate for a stretch here and there at a brisker pace, and once had it over 70mph briefly under its own power. | | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Complete build of "Dually" bed Replace fuel pump, (old one quit) Re-wire with Jim Carter Harness retaining 6 volt Restore Gauges and Speedo Replace 5:14 Pumpkin with 4:10's Have new cab, door seals, ect to be installed this winter Also hope to fabricate and install rear bumper Drive and Enjoy! | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | 12 volt alternator Radial tires Front disc brakes Juliano 3 point shoulder harness Newer Chevy rear end with 4.10 gears Large outside mirrors Newport wiper conversion Halogen headlights Altman door latches
1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | Installed a T 5 trans. which made the truck 100% more drive able , and as an experiment a coat of Home depot bear latex house paint semi gloss as close to the original as possible and even coated a section with automotive clear coat. Its been 2 years and 6000 miles and its still hanging in , but easier to clean where the clear coat is. I did the whole job for $75.00 including masking tape. I used a typical spray gun for the job.
good planning is no substitute for dumb luck
| | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | 12 volt alternator disc brakes on the front tapered roller bearings 16 inch 1 piece wheels HID headlights '56 GMC 270 with 3 speed trans 3.90 rear axle gear bendix brakes on rear fuel tank under the bed in rear electric wiper radial tires turn signals Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 2012 Posts: 441 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 441 | 1947 - dally 3800
When mine goes back together it will have the 4:10's and 8r19.5 rims with radials 12V. Alternator, probably an electric fan. 1962 full pressure 261, stock carb, intake and exhaust. SM-420 Fully rebuilt front end, sandblasted and painted frame Cab will be "patina" farm fresh. New passenger floor panel and drivers cab corner.
Still figuring what to do for a wiring harness, wipers, oil filter and fuel pump
Goal: roll under its own power for Labor Day parade 2017
1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | 1949 3800 flat bed A complete rebuild (Still in progress)
Also blasted & painted the frame I replaced the 217 with a 283 SM-465 4 speed with a hydraulic clutch 14 bolt rear diff, 3.93 gears 17" 1 piece steel rims 12 volt wiring harness Alum Radiator with electric fan Harrison Deluxe Heater Dual Master cylinder with booster L&R Inner & Outer Cowls, R/side floor panel and L/rear cab corner. painted the interior & exterior Every seal on the cab and doors All the bed boards were planed from reclaimed red oak timbers.
Next adventure on it is to install hanging pedals and add a steering gear box.
| | | | | Joined: Nov 2012 Posts: 441 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 441 | That T-5 sounds interesting. I would like to research bellhousing match and where the shifter protrudes from the floor. I imagine it would improve the driving experience. - Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Nov 1995 Posts: 5,714 62401 | | 62401 Joined: Nov 1995 Posts: 5,714 | '49 3804 here. -- Upgraded to early 261 -- Stock SM420 -- Upgraded the rear axle to the 4.10 gear set -- 17-inch wheels (bias plys) -- Added seat belts -- Original Huck brakes and they work just fine. I drive defensively so have not yet had to deal with a stab/panic brake situation. -- Cruises 65 MPH, dashes to 70. Slow on acceleration, though. Easily cruises at 80 to 85 mph ... on the trailer  -- Not a daily driver. That's what the '88 Army-surplus Hoopty van is for  And farm work gets done by the two Fjords ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2016 Posts: 11 New Guy | | New Guy Joined: Jan 2016 Posts: 11 | 1950 GMC 250 w/ duals and flatbed
Fairly new to this site and finding it a great resource.
In past 10 months
Replaced front axle with one that's not bent Replaced king pins Replaced front spring shackles and bolts Replaced both front main springs. Replaced front brake shoes Replaced front wheel bearings and seals Replaced rear wheel bearings and seals Front end alignment Replaced all four brake wheel cylinders Removed worn out 228 and installed a 1955 270. 6V pos ground to 12 neg ground w/ alternator Installed headlight relay Replaced rt park brake cable Welded up cracked inner fenders Welded cab floor cracks Replaced cab mounts Cleaned all mouse crap out of cab New cowl rubber and hood rubber bumpers
Currently this week: Replacing 3 u joints Replacing carrier bearing and bearing cushion
Next: Rebuild master cylinder Replace front fender supports Replace battery tray bottom Rebuild door hinges Install three whiskey barrels on flatbed just cause i want to. Drive the crap out of it after all this snow goes away.
Pete. You can't run with the big dogs, if you pee like a puppy.
1950 GMC 253 1 Ton 1965 Sunbeam Alpine / 2.8L V6 06 Dodge/Cummins | | | | | Joined: Dec 2006 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 103 | Gonna be a WHILE before that snow goes way! | | | | | Joined: Jan 2016 Posts: 11 New Guy | | New Guy Joined: Jan 2016 Posts: 11 | New carrier bearing and bearing cushion installed Replaced all three u joints. Put it on jackstands are ran it to 50 mph. Vibration is significantly reduced, but not al the way gone. Suspect the slip joint. Good enough for now.
Rewired firewall forward. Much better/ Rebuilt master cylinder and bled brakes. Waiting for the roads to clear of snow for a test drive.
Next. Off to the Portland swap meet in April in hopes to find at least one rear brake drum. Maybe even a metal frame for flat bed rebuilt.....hey, a guy has to dream, right?
Next winter...remove rear springs and have worn main springs rebuilt and new spring perch bushings installed. Fix leaky rear diff while it's down for the winter
EDIT. New battery tray installed.
This is fun.
1950 GMC 253 1 Ton 1965 Sunbeam Alpine / 2.8L V6 06 Dodge/Cummins | | | | | Joined: Jan 2016 Posts: 11 New Guy | | New Guy Joined: Jan 2016 Posts: 11 | The snow went away and roads cleared. Took Jimmy out for its first ride after a lot of work, including engine change, driveline work and front end work. Runs much stronger than before and wobbles are almost gone
Two troubles appeared. 1. It died one time at a very busy stop light....thankfully started right back up with a little choke.
2. I still have a vibration that starts about 25 MPH and goes away at 40. Much less intensity than before. Seems to be about driveshaft speed. That leaves a slipjoint suspect or driveshafts simply need to be balanced. Another day..
No Leaks!!! It was good to have it on the road again.
