5 members (Otto Skorzeny, Shade Baby, msmall, KEVINSKI, 1 invisible), 71 guests, and 6 robots.
Topics128,269
Posts1,058,401
Members48,485
#12025 12/03/2003 6:33 PM
i have a 59 chevy 3/4 ton i am restoring. it has 4-wheel drums, and i wanted to convert to a power disc/drum setup. i haven't been able to find a conversion kit for 8-lug. please help! any suggestions?
'59 Chevy 1-ton
'03 **** Lightning
'96 Kawasaki 1100 zxi
#12026 12/03/2003 7:39 PM
Anonymous
Unregistered
Anonymous
Unregistered
#12027 12/03/2003 7:50 PM
brothers truck parts sales one for the newer independent front ends would not work on youre straight axle but you might check it out and see what parts that thay use
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#12028 12/03/2003 10:03 PM
Look to the '76-'84 Chevy/GMC 3/4 tons as a potential source of parts, they had front disc brakes. Don't plan on a direct swap, but it's something to start with.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#12029 12/04/2003 7:47 AM
Quote
Originally posted by Ken:
It has been done before
While I agree that he made it work, I completely disagree with the use of cold rolled steel for suspension and brake structure. It is an easy way to manufacture, but downright horrible from a safety aspect.
Fred
52 3600
69 C-10
#12030 12/05/2003 1:39 AM
Hey Fred
I know mild steel is a BAD idea for brake parts. I did notice he was trying to find someone who could make the brackets from hardened steel. What material would you suggest, and if a guy had a pattern for the bracket, backing plate and any required spacers, would any decent machine shop be able to fab them for a reasonable price? Or is this something reserved for a more high tech operation? Not being snarky, I really don't know that much about the metalurgy and metalwork involved.
#12031 12/05/2003 1:44 AM
T-1 plate steel ,, had someone make a wrench for me out of that stuff grin
