| | | Forums66 Topics128,125 Posts1,056,337 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 15 New Guy | | New Guy Joined: Mar 2015 Posts: 15 | I have a 1940 Chevrolet 1-1/2 ton panel. I'm wanting to remove the body so I can paint the frame. I know there is more than one way to skin a cat, so what is the best way to go about doing this since the body is so large and heavy? | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ibdots13, when I had my panel body ready to set off I recruited my neighbor and 3 other big guys. They picked the body up and set it on two rolling pipe made supports..... But then My panel is only a 1/2 ton so you would probably need SIX people. But it can be done the hard way! http://i140.photobucket.com/albums/r19/LutherParris/52Panel/PanelBodypics029.jpg | | | | | Joined: Mar 2015 Posts: 15 New Guy | | New Guy Joined: Mar 2015 Posts: 15 | Thanks for the help fellas. I think I will lean toward option B. I am short one large crane or that would be a great option. Another question, the rear roll pan under the barn doors is gone. Should I install a new one before I remove the body? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I would at least cut the old one out and tack the new one in place before removing the body. Might just save you from twisting things out of alignment. JMO
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I was lucky enough to have a friend offer his lift. body lifted 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
