4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#1201970 01/29/2017 2:10 AM
I have 56 Chevy 3200. I was wondering if anyone has used a kit to mount a later model ps pump on the outside of the frame ahead of the axle. If so is one any better than the other? I see several companies offer some form of kit. Thanks for reading
http://www.classicparts.com/1947-59-Power-Steering-Conversion-Kit/productinfo/76-977/#.WI1tqk0iyic
This is the kit I used on my 52 panel. The instructions for your mounting on your 56 may be a little different. I used this kit and a Saginaw steering box (remanufactured) from the local parts house.
Do some research and you will find several pitman arms can work from a junk yard rather than pay the high price!
I once had a nice article showing the steps to do it for our years but the page is "no longer available".
EDIT: I think the instructions that come with this kit show both for the AD and the TF series so you would be good to go.
I was looking at that one as well as one from performance online. Very similar kits however pol offers the pitman arm about half the price. They also recommend 6 degree shims for the springs. I got the ps gear and column from 84 truck. How did the kit work for you?
The kit worked well for me and I have driven my panel quite a bit. Works well.
I followed Alvin's tutelage on how to add the power steering on my '49 and it was much easier than I had imagined.
Dang it Carl and Alvin...why didn't either of you do a tech tip? I see we are missing one on the list. Reckon this would work on my 3600?
Allen
1974 Stingray Corvette
Slight change in the thread, but has anybody found a power steering box out of a newer heavy truck that will work in a 2 ton COE?
