5 members (3800GUY, Uncles51, Gdads51, J Lucas, Otto Skorzeny), 94 guests, and 2 robots.
Topics128,127
Posts1,056,674
Members48,450
Ok, all, I had to change one of my headlights the other day (first one in the 3 1/2 years I've had it), and although I've had it off a few times for cleaning and inspection, I didn't notice till this time that the clip for the screw on the bottom of the trim ring around the bulb is barely there. The clip is still there, but the hole that the screw attaches to has some of the metal that surrounds the screw broken off. There's just enough to get a bite on the screw threads, but I need to replace it. I checked Classic Parts catalogue, but don't see any there. Where can I find these clips? I'm talking about a single clip at the bottom (6 o'clock) of the trim ring, and is mounted to the fender (maybe the bucket, I'm not sure), and extends up to the point that the screw goes through the ring. I haven't checked my other catalogues yet, but I thought I'd check with all you well-informed bolt heads first. Thanks for any help in finding a couple of these.
"When I rest, I rust"
1951 3100 5 window w/ '56 235
Check the "HELP" tree at your FLAPS they were used for a very long time.If you could bring one with you.
Pete
As Pete suggested try the help Isle. If no luck try JimCarter.
LG605 at JCarter for 4.75 I had to have them for my panel. They pop rivet on the headlight bucket.
Securing Clip for Headlight Ring 1947-1957 Chevrolet and GMC
Item Number: LG605
Jim Carter Trucks
http://www.oldchevytrucks.com/cart/index.asp?sdes=LG605
Securing clip, headlight bulb backing ring, fits on bottom of bucket - No Photo
HLBC47
American Classic Truck Parts
http://www.americanclassic.com/asp/...&iyear=1954&ytype=to&exyear=
- Lonnie
- Lonnie
My '54 3104
Thanks, guys, I knew you'd come through! (And I just got an email flyer from Jim Carter this morning. Should have known!
