| | | Forums66 Topics128,127 Posts1,056,675 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | Ok, all, I had to change one of my headlights the other day (first one in the 3 1/2 years I've had it), and although I've had it off a few times for cleaning and inspection, I didn't notice till this time that the clip for the screw on the bottom of the trim ring around the bulb is barely there. The clip is still there, but the hole that the screw attaches to has some of the metal that surrounds the screw broken off. There's just enough to get a bite on the screw threads, but I need to replace it. I checked Classic Parts catalogue, but don't see any there. Where can I find these clips? I'm talking about a single clip at the bottom (6 o'clock) of the trim ring, and is mounted to the fender (maybe the bucket, I'm not sure), and extends up to the point that the screw goes through the ring. I haven't checked my other catalogues yet, but I thought I'd check with all you well-informed bolt heads first. Thanks for any help in finding a couple of these.
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Check the "HELP" tree at your FLAPS they were used for a very long time.If you could bring one with you.
Pete
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | As Pete suggested try the help Isle. If no luck try JimCarter.
LG605 at JCarter for 4.75 I had to have them for my panel. They pop rivet on the headlight bucket.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Securing Clip for Headlight Ring 1947-1957 Chevrolet and GMC Item Number: LG605 Jim Carter Trucks http://www.oldchevytrucks.com/cart/index.asp?sdes=LG605Securing clip, headlight bulb backing ring, fits on bottom of bucket - No Photo HLBC47 American Classic Truck Parts http://www.americanclassic.com/asp/...&iyear=1954&ytype=to&exyear=- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | Thanks, guys, I knew you'd come through! (And I just got an email flyer from Jim Carter this morning. Should have known!
