2 members (Hotrod Lincoln, 1 invisible),
137
Mod | | | Forums66 Topics128,196 Posts1,057,385 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | After my frame is completely sanded down and coated with 2 coats of epoxy primer, what kind of black paint should I shoot it with? I'll be using my spray gun I assume, and I want it to be treated for rust, so what are some recommendations? Thanks!
1952 Chevy 5 Window Restoration
| | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 |
New deal for old steel
| | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | I'm gonna make an unusual reccomendation. Firstly though, I've used Por 15 many times and my main gripe is that it is really picky about surface preparation and even when you do everything they reccomend the results are sometimes frustrating. That said, Rustoleum has served me well. You can spray it by reducing about 20% and it flows really nicely. Give it several weeks to cure and it is really durable. Anyway, consider a product that is readily available and easy to use before you use some of the specialty paints. Another to consider is PPG's DP 90, an epoxy primer that is super durable and looks great on chassis because of it's low gloss finish.
Joe | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Endura. Hard, hard paint (but not to hard to chip). I am painting my frame with it next weekend. My boss, owner of the body shop, uses it for all his frames. They are still shiney after many years. You only want to do it once. Good Luck. Colin | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you already primed it with good epoxy primer then just shoot it with good automotive paint. POR and Zerorust are for painting over rusty metal. Some would argue that a soft paint is better for frames because rock chips will not flake off the top coat.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | i used hemeright and a brush the stuff is rock hard looks like glass 50 bucks a gallon no primer needed | | | | | Joined: Feb 2006 Posts: 20 Junior Member | | Junior Member Joined: Feb 2006 Posts: 20 | Blake, Take Josiah's recommendation. Colin has the right idea about Endura but even though it is tough, it should only be used in a well vetilated area like a spray booth. Do your neighbors and your family a favor and don't use it at home, and only with all the right safety equipment. A good automotive paint of the same product line will serve you well. I use it on my frames both vehicle and motorcycle. Good Luck
Allan S Langley B.C Canada
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Blake, I used a epoxy primer and painted with a gloss black acrylic enamel with hardener. It is currently on a stand until I get front and rear finished. If I did again I would use a black primer as I didn't get the coverage in some areas as well as I liked. Pics below. Dan http://community.webshots.com/mypho...=2951450480071274430&security=qeOjmO | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you can paint w/ por 15 over clean metal if you have primed the frame first DON"T use por or zero as they must go directly to metal and not over any other type paint/primer. so just shoot it w/ a good epoxy paint
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I would suggest a good oil base enamel since it is already primed. I used some paint from tractor supply on my trailer and am happy with the results. Unless you are building a show truck that will not have mirrors under it for people to gaze with admiration at your undercarriage I would not worry about it too much as anything you put there will look like crap after the first mud puddle, rain storm or snow fall. As long as it protects then you have done all you can. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | You can also consider a layer of undercoating sound deadner, and/or use what I used on my jeep - I got chassiskote at a swap meet and really liked they way it worked. Shiney and hard. You could proably also use pickup truck bed liner for that matter. That's some durable stuff. | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I have to vote for ZERO RUST. I did my frame with it. Also I put some on a completely rusted old fence post 2 years ago I didn’t sand it or clean it. Two years later it looks great and it is out in the direct rain and sun.
Plus ZERO RUST doesn't need a top coat. Or a primer and if finishes out smooth. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | BTW, my truck frame is Zero Rust on my 59. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | If his frame is already primered then the ZR will not work well as it needs to be applied directly to the metal. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I've used equipment enamel from the IH-Case dealer (Iron Guard). You can paint it on clean steel or on primer. It comes in various colors and also in quarts, gallons and spray bomb. | | |
