Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Wayne67vert, 78buckshot, 1 invisible), 78 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#120075 03/30/2006 3:49 PM
What is the cheapest and or best welder to use on auto body parts?
I don’t want a super set up I just want something that will help me patch some panels and weld some stuff like angle iron and small metals.
Can I settle with a 110V
#120076 03/30/2006 5:09 PM
Anonymous
Unregistered
Anonymous
Unregistered
110VAC works fine. If you have a tool rental place near you they typically have the small wire feed welders for rent. I have also seen them in HomeDespot for rent but they are set up for flux core and a gas rig would be better for sheetmetal.
If you have a significant amount of work to do then go buy a rig for around $400 you can get a Clarke model welder from Harbor Freight and go buy your own bottle for shielding gas from your local welding supply. Once you are done you can sell it and get most if not all your $$ back. At least that is how I got a green light from my management. It would be better to go with a lincoln 135 Amp welder though instead of the Clarke just from the resale aspect. Clarke is not the highest quality but will get the job done for you at least for one or two projects.
#120077 03/31/2006 12:24 AM
Ill check out the Harbor freight. And Clarke
What about the ones they sell at Wal-Mart.
#120078 04/01/2006 4:55 AM
I know the gas welder would give me a cleaner weld on sheetmetal but since I couldn't afford it, I bought the Campbell Hausfeld flux core welder from Wal-Mart. I have used it to repair a rear quarter panel on a '67 Dodge Dart, repair cab corners and cowl area on '54 Chevy 3100. Now I am working on my '70 C10. I have repaired the right side floor pan and repalced the rocker panel, made a new battery tray and repaired the badly damaged radiator core support. It has done an exceptional job, just have to do some grinding to clean up the welds but I am ok with that. Since I am not an expert welder I would probably have to do the grinding anyways. Check out my link below to see some of the work.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#120079 04/01/2006 5:07 PM
Thanks Bigbass,
By the way nice Dart, I have been itching to get me an old Mopar project lately. They had some cool cars in the 60,s and 70,s
#120080 04/02/2006 6:54 AM
I have to disagree about Clarke welders. My 100EN is built like a rock, and they have great customer service.
1954 GMC De Luxe COE
#120081 04/05/2006 6:24 AM
I have a century 125 GL 110v welder and its done a nice job on bodywork and building the bed on my 59. Its flux core. Yeah, its a bit messier, but I'd end up grinding/sanding anyway.
