4 members (1955 1 Series, dgrinnan, tclederman, 1 invisible), 320 guests, and 4 robots.
Topics128,154
Posts1,057,015
Members48,460
I need to pump up some tires at a remote location and wonder if anyone has had any luck with the small air pumps that run off cig lighter plug. And I am looking at a air operated grease gun. something in the under $40 range. anyone have a reliable one? Thanks for any ideas
Had a flat up town about a month ago. I had the little gizmo behind the seat and let it run for 15 minutes and could tell it did anything on my Silverado. If the tire has no weight on it I think it may get you enough to get to a station??? I do not like them!
Let us know your experience with the air grease gun. I may be interested in one of those myself.
They work OK on little pee-pot cars like Corollas or Civics or smaller, and take about 7 - 10 minutes to get to 30 PSI. A little faster on bicycles and wheelbarrows if they're near the vehicle.
Using them on large truck tires is mostly a waste of time.
That's what I found anyway.
Thats sorta what I thought on the pump. Its for a tractor tire 16.9 14 x 24. Takes about 10 min with a 2hp compressor . Want the grease gun as arthritis has set in in both hands.
Milwaukee make a cordless grease gun heard no complaints anyone else have a comment
We had the Lincoln cordless back in the early days. Worked great when it did, but it didn't last very long.
Sorry it took so long to reply . Went to town yesterday and stopped at my favorite parts store. They had a air operated grease gun for under $30. Looked good so I brought it home. uses the large grease cart. Loaded it up today and greased a old outboard. worked well, had enough pressure to push the old grease out. Think on the air comp I am going to find a small generator to drive my pancake compressor and see if that will blow up the tire. LG
Moderated by  MNSmith
