8 members (Gdads51, LAROKE, Phak1, JW51, Nick in Manitou, FAST55, Bill Hanlon, dt235sd), 86 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
#1200215 01/18/2017 6:03 AM
Can anyone tell me what is missing on the connection of the alder level and the cable? It's the same on both sides
http://i430.photobucket.com/albums/...F5760BFD-9DD2-47C8-B508-CE26BCC8BCCE.jpg
1949 Chevrolet 3100 Suburban Carryall
"Bad Guy"
More pix in Photobucket
1950 Chevrolet 3100 3-Window
More pix on Photobucket
1966 GMC Suburban Carryall Custom
"Big Guy"
What is an "alder level"?
Nonetheless, it takes at least a minute for your photo to open on my system. I had to wait for three pop-up windows to open, so I could close them in order to see your photo.
I think this is your photo? I do not recognize what is in that photo?
Sorry, slider lever
"Bad Guy"
"Big Guy"
I couldn't tell from your picture what's going on.
But here is a photo of the seat adjusters from my '51. They're in the relative positions with the front of the truck toward the top. There's a rod between the hole in the lever on the left side connected to the slot in the latch lever on the right side. Maybe that will help.
I would think that the cable would connect the two latch levers the same way, running across the seat riser.
The 47-50 seat frame works off a continuous cable that winds across pulleys (underside of the frame). The slides are different then the 51-55 style which uses a release rod.
https://www.flickr.com/photos/advance-design_parts_co/29437000195/in/album-72157631868452754/
What you are missing are two small square plates that bolt to the hole in your picture. These small squares secure the cable to the slides when the bolts are tightened.
Cable and pulleys, eh? No wonder GM changed it. The cross-rod link seems like a much simpler system. Maybe at the cost of a rod running across under the seat.
Moderated by  ndkid275, Phak1
