2 members (NorthCoast3800, DadsFirstPickup), 53 guests, and 3 robots.
Topics128,153
Posts1,056,849
Members48,456
I have found a tail light assembly for the rear door of my 46 1 Ton Panel. It appears correct with the plate holder and two single filament bulbs. I have not been able, yet, to find another unit for the other door.
How have you solved the problem of getting the proper lights on the back? The rear doors will not clear mounting much on the bumper.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
My custom '48 Burb has the tail lights cut into the rear bumper.
Leo Offline
Moderator
Moderator
Some of us have the optional lights mounted on the side of the vehicle, halfway up.
+1 for bumper lights.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
I have thought up two options, one was to mount later model lights on the doors. I have a left and right, ready to reassemble. The other option is some bullet lights on the side. I also have two earlier model lights that mount the traditional style lights. I don't want to look too modern, but the older lights aren't really lighting my fire in the looks category.
The door mount AD style with the bullets lights for turns may be what I end up with. Still working this out in my head.
1946 1-ton Panel
A lot of guys use 39 car tail lights.Not a bad option.Ive been wondering about using a small LED lights behind the rear door glass.
1937 Chevy 1/2 ton panel
I use the original-option style side-lights/lamps for brake/driving/turn (now with 6v dual "filament" LED lamp/bulb) and the original lamp on the rear driver's-side door with a 6v dual "filament" LED lamp/bulb (brake/driving "lamps"). Much brighter than original 6v bulbs - as bright as 12v LED bulbs.
