0 members (),
148
0
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I installed the harmonic balancer and had 2 intake/exhaust bolts that needed the keepers ground so they would be flat against the intake manifold and Fenton headers.took care of that and tightened the bolts. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Rear springs disassembled, cleaned, prepped, painted, ready for reassembly. Rear end removed, prepped, painted, ready to install. I still need to locate a 4.10 for this 1 ton but I'll drive her with the 5.14 until I do. Last thing to do on the chassis is the exhaust and then primer is a spraying! | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | GMC 1 ton front sheet metal assembled for test fit of panels before primer. My wife came into the shop this afternoon and said, "Oh wow! It looks like a truck again!" It sure went smoothly except for a couple spots where I need to clean up some welds, a couple rubbing points and radius a few corners. I'm about to try to get the hood aligned to set gaps next and anticipate it being a pain. Any tips? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | There is a Stovebolt Tech Tip on fitting hoods. I can't figure out how to link stuff but just go to the Tech Tips page and you will find it.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | GMC 1 ton front sheet metal assembled for test fit of panels before primer. My wife came into the shop this afternoon and said, "Oh wow! It looks like a truck again!" It sure went smoothly except for a couple spots where I need to clean up some welds, a couple rubbing points and radius a few corners. I'm about to try to get the hood aligned to set gaps next and anticipate it being a pain. Any tips? Tips found here
~Jim
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Thanks fellas. It went fairly smoothly tonight. Glad it wasn't in paint but I got it looking pretty good. Now time to tear the whole thing apart for clean up and then primer! Yikes! This is really happening! | | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | WOW ... this is crazy! I haven't been on the page for years and it remembered my password. Well done. I just thought I'd brag that I finally installed vacuum assist brakes on the Toad. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I bolted the cab in place and have the radiator and core support I place. | | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Installed new front shocks, modified the bumper brackets so that she sits straight and level, and did a little headlight wiring.
1955 Chevy Cameo 235 engine 3 speed transmission
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Managed to complete my heater install,I snagged a pair of Austin Mini demister hoses for nothing (the best price). Makes a change actually being able to see where i'm going..;)
Of course this just coincided with a mild snap and daytime temps of 50 plus degrees!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | Trying to fit the full floor boards and the passenger side kick panel. "Factor Fit" (?) ! Measuring it with a tape measure shows it is larger than the stock one on the other side. Better than being too small I guess. Going to take some cutting to resize it along with some bending and hammering.
Chuck
1950 Chevy 3100 Deluxe Cab A few Harleys and '76 Triumph Bonneville
| | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | Replaced the vacuum wiper motor with a 6 volt electric one. Don't plan on driving in the rain but if I do I don't want to depend on the old vacuum wiper motor.
1949 Chevy 4400 216
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | This weekend I was planning on getting my running boards, rear fenders and bedsides ready to go to the blaster for cleanup and primering. But I wound up finding a weld that needed grinding here, a crack that developed there, and a dent or two that needed a little more work. So didn't get them there. Close though!
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Got hub seal in and put hub, bearings and single tire on so that I could take other hub off to replace it's seal. Got that one off and took it home n cleaned up, along with both tires. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Changed the oil, lubed the frontend, tightened the F wheel bearings and adjusted the Huck brakes. Then took it on nice relaxing cruise with the heat on, much needed therapy... | | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | got cab in the shop and taking wonsows out, to start getting the cab ready, waiting in stuff to get the motoe ready, sont likemuch,,,,,, Monshine Mike | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | A few weeks ago,on the way home from some friends, after a nice dinner, the headlights went out on my '55.`(fun stuff, no street lights!) A moment or so, and they came back on. Then they seemed to work ok for a while. Last week it happened again, I tapped the dimmer switch and they came back on. So, I ordered a new switch from LMC, and when I was installing it, noticed the spade connectors were loose and corroded. Lights work good now, I'm thinking a good cleaning and fixing the spade connectors would have solved the problem....
| | | | | Joined: Jul 2016 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2016 Posts: 21 | I got one kingpin done and am letting the other side soak in a nice PB Blaster tonic for a few days.... | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Got new Lokar throttle cable and swap meet pedal assy hooked up to the my 4 barrel Holley on the flatbed 235, today a test drive. Carb is 390 cfm, on an old Clifford intake mated to old nickle plated Corvette exhaust. love it! | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Block sand, block sand, block sand, block sand...ugh | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I spent more money on the old truck. That should count for something. I ordered some new dash switches, a gage cluster and some new grommets for the firewall. | | | | | Joined: Jan 2011 Posts: 70 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 70 | Fun in the shop today. Pulled the battery, topped it off and set on the charger. Pulled the crusty ground strap and replaced it. While I was down there I saw the fuel line was kinda ugly and since I didn't have a filter-- I robbed the filter off a different project and trimmed some new line, installed all at the fuel petcock. Messed around with measurements of the bedsides for the new jumbo box project.
1951 GMC 250 Open Express 1968 C10 Suburban 1971 C20 Pickup
My Dad told me "Son, never hit a man in anger- unless you're certain you can get away with it"
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Greased the chassis and adjusted the brakes after the big trip. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Wind is howling through the trees, buffeting the snow against the doors as the Nor'easter ramps up. The coal in the potbelly stove is glowing bright, keeping the shop toasty warm. Stripping everything off the frame of the '51 COE preparing to remove the old engine and trans. All's right with the world. | | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | The first step of dragging it out of the weeds! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sounds poetic.
After you have have dragged it out of the woods, will you remove all the cab/front-end sheet metal, and maybe the radiator? | | | | | Joined: Jan 2017 Posts: 22 New Guy | | New Guy Joined: Jan 2017 Posts: 22 | I will remove the cab, bed, fenders, basically any usable sheet metal from the frame and then start with the sheet metal patches and bondo | | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | The yellow 261 was installed in the 47 3800 dually. Of course the Rock Auto transmission mounts were too wide and the engine doesn't seat right into the frame. They will be changed out. followed right behind the engine with the SM420, carrier bearing and driveshaft. Need a good source for the dual outlet water pump..... Best my friends - Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Block sand, block sand, block sand, block sand... Lunch, block sand, block sand, block sand.... Yeesh. And to think, I'm still on my first project truck! 2 more to go! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | I got the GMC 228 unbolted and ready to pull. The '47 is getting ready to welcome a 1955 235! | | | | | Joined: Apr 2010 Posts: 23 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 23 | I tore down a NAPCO 1/2 ton front axle. So far I have 3 out of 4 trunnions that will need welding up. 2 were completely broke off and one other was loose and would have failed soon. I'm going to have all 4 welded up. Then I got to spend most of the day cleaning 60 years of black, gooey mess up. It should be welded up this week and I'm ordering parts to get it all back together.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Finished this up yesterday... on my '65 c10 : 02/17/2017 — add a fuse block Now I have to figure out why my blinkers suddenly stopped working. -W | | | | | Joined: Dec 2012 Posts: 122 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 122 | Replaced both front spring shackles and rear bolts and bushings today. Not a big day, but progress is progress! Just keep peckin' away at it... | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Finally got around to swapping out the dropped spindles for standard ones. No more tire rubbing!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Spent six hours heating and banging and prying stuck brake drums off my new project. 1958 Chevy Viking two ton with hoist. Got it running and now working on getting it to stop.... Always a good idea!!!' | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Well, if any of you have a '65 C10 and your blinkers stop working... check this plug here : blinker plug - 1965 Chevrolet C10 It seems to work better, plugged in. /sarcasm  -W | | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | Both rear brake cyls and all of the old brake lines removed, heading to get custom bent lines and new crush washers tomorrow from Gregg Distributor. New master cyl installed and all 4 brake cyls replaced. Cleaned up all of the brass unions, bolts, pivot points and original shoes ready to reinstall. | | |
