0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | as far as i can tell - engine is 350 3 speed auto with a 400 tranny - it is a 1963 chevy - six lug / original rear just did a brake job/suspension/shocks/60's rubber/ 10inch wheels - what can i do to lessen the noise
jsalchevy63
| | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | First thing that comes to mind would be to slow down Actually you can insulate the floor and ceiling with a sound deadening material. You could increase the tire size to lower the RPM's. Change the muffler or exhaust exiting point. Just some idea's off the top of my head.
Joe
| | | | | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | forgot to add new dual exhaust - just finished redoing the interior / used 3 cans of that bedliner stuff to the flooring then on top some sound deadner padding - the noise is mostly when slowing down / when is downshifting :confused:
jsalchevy63
| | | | | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | forgot to add - new dual exhaust to the rear - just finished redoing the interior / used 3 cans of that bedliner stuff to the flooring then on top some sound deadner padding - the noise is mostly when slowing down / when is downshifting :confused:
jsalchevy63
| | | | | Joined: Sep 2002 Posts: 9 Member | | Member Joined: Sep 2002 Posts: 9 | Check rear end. Most of the howling noises I've dealt with are rear gears or bearings. If you had a manual trans, I'd of said look there too, but with an auto...
JKU72 56 3100 68 Suburban
| | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Very possible that the whining noise is, indeed the transmission. I used to have a '72 Malibu with a TH350 that did the "whining" or "whirring" thing on decel all the time...a couple of local old timers told me that was pretty normal for the GM 3-speed autos. Hope this helps. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | you are right - since it is a truck with limited sound barriers - local shop tells me to double the floor padding with good sound deadening material this will help cancel the noise - got to check those bearings though :rolleyes:
jsalchevy63
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | When was the last time you changed the gear oil in the rear axle? Won`t hurt to inspect the bearings and gear teeth for play while you are at it.
