3 members (Gdads51, Peggy M, Jon G), 118 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
#1193 06/04/2004 2:53 AM
as far as i can tell - engine is 350 3 speed auto with a
400 tranny - it is a 1963 chevy - six lug / original rear
just did a brake job/suspension/shocks/60's rubber/
10inch wheels - what can i do to lessen the noise
jsalchevy63
#1194 06/04/2004 3:19 AM
First thing that comes to mind would be to slow down smile
Actually you can insulate the floor and ceiling with a sound deadening material. You could increase the tire size to lower the RPM's. Change the muffler or exhaust exiting point.
Just some idea's off the top of my head.
Joe
#1195 06/04/2004 5:55 AM
forgot to add new dual exhaust - just finished redoing the
interior / used 3 cans of that bedliner stuff to the flooring
then on top some sound deadner padding - the noise is
mostly when slowing down / when is downshifting :confused:
jsalchevy63
#1196 06/04/2004 5:57 AM
forgot to add - new dual exhaust to the rear - just finished redoing the
jsalchevy63
#1197 06/04/2004 9:59 AM
Check rear end. Most of the howling noises I've dealt with are rear gears or bearings. If you had a manual trans, I'd of said look there too, but with an auto...
JKU72
56 3100
68 Suburban
#1198 06/04/2004 4:11 PM
Very possible that the whining noise is, indeed the transmission. I used to have a '72 Malibu with a TH350 that did the "whining" or "whirring" thing on decel all the time...a couple of local old timers told me that was pretty normal for the GM 3-speed autos. Hope this helps.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#1199 06/07/2004 7:13 PM
you are right - since it is a truck with limited
sound barriers - local shop tells me to double
the floor padding with good sound deadening
material this will help cancel the noise - got
to check those bearings though :rolleyes:
jsalchevy63
#1200 06/10/2004 1:38 PM
When was the last time you changed the gear oil in the rear axle?
Won`t hurt to inspect the bearings and gear teeth for play while you are at it. smile
