1 members (52Carl), 77 guests, and 4 robots.
Topics128,187
Posts1,057,316
Members48,468
I am wanting details on a advances front and rear suspenion for my 53 3100 Chevy. Disc brakes and power steering capabilities are important. Also the ability to utilize my stock six lug wheels.
Why the Grand Marquis subject line? That's not keeping your stock 6lug. It all starts with your budget. Start here with forum searching and vendor catalogs for your options. Then it be becomes limited by your skills, tools, work area, etc
NHluvstruck...
1951 3100 5-window,.sold, regretted
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
If you go with a disc brake set up the odds are that you will have 5 lugs (depending on what you buy)
If you want 6 lug then you'll need a disc kit for 6 lug and you'll have to re-drill the axle holes in the Marque.
...and lastly, be sure ALL the lug patterns are the same on the front and rear so you do not have to have two sets of wheels for a spare!
Research...research, research...
The FoMoCo Panther body chassis has a very wide track. If you use one of those IFS setups with a typical offset wheel your tires are going to stick out past the fenders and your rear track will be significantly narrower than the front. I wouldn't really recommend it. I have seen guys take the entire rolling frame from a Panther car and shorten it and modify it to fit under various model older pickups and it works great, but there again you're limited on your wheel selection if you want it look right.
1950 4100 - unrestored and driven weekly for almost no reason at all.
Thanks for the reality check guys. I would really like to keep the look and take advantage of a good comfortable and safe ride. I started out as a diehard "all stock" rebuild. You know bench seat with fuel tank behind the front seat etc.. I have seen too many upgrades that I am leaning in another direction. I guess holding on to my stock six lug wheels is my last chane to keep a look I realy want to perserve. Yes more research for sure. All the advice is appreciated.
