4 members (Hotrod Lincoln, FishinToms53, Bill Hanlon, Charles in CA), 71 guests, and 3 robots.
Topics128,087
Posts1,056,000
Members48,430
I have been hunting for a few weeks now and keep finding no results. Briefly I am restoring my 1952 C3100 and am looking for the radiator support bushings and bolts. If memory serves from tearing it apart some time ago, the bushings/shock absorbers were rubber and a spring. Please point me in the direction to find these.
Joe, the radiator mounting pads and bolts are available from the vendors like Classic Parts....JimCarter Parts....American Classic and Filling Station or Chevys of the 40's.
IF you are close to Shelby N.C. you can go to Tommy's Truck Parts out on Hwy 74 and get them from him.
I have a 52 but can't remember the "springs" but that don't mean they weren't there. I had a basket case to start with and ended up going V8.
Or you can post an ad in Parts Wanted.
There are no springs on my '52 radiator mounts. Just a rubber pad with a bolt through it on each side.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
32-46 Chevrolet radiator mount had a spring.
Some (all?) New Design GMC truck's radiator mounts had a spring.
http://www.oldchevytrucks.com/cart/product.asp?prodid=MER827&i=10290|||||
A spring is not listed or shown in any 47-54 Chevrolet truck radiator mount specification/illustration.
My '57 GMC has the exact mounting hardware used that Tim linked. I think it is a GMC verses Chevrolet difference. From what I have found is that the GMC uses a completely different radiator support as well as how the front fenders mount to the frame near the grill. The Chevy assembly manual does not show these springs and u-bolt being used, at least not that I could find.
I was actually just about to put up separate post asking about this hardware, until I saw this. Could somebody tell me the order this mounting hardware goes? Which way does the U-bolt go through the frame/radiator support and where the rubber and metal plate go in relation to the support collar? It's been a couple years sense I tore all this apart and cannot remember.
Thanks for all the pointers. If anyone can relay or show a picture of how it mounts, it would be greatly appreciated.
