| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Nice Lou...did you have to blast or do anything to the frame/springs before you had it covered?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Very NICE. Could you show a couple photos of the seat bottom, bottom and the back of the seat back?
I installed the same covers on my 51 seat and am only about 95% happy with my craftsmanship. Curious about how a professional did it.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Yes my seat was in very poor shape. Bought it used; looked like it came off the titanic I had to form and weld 1/8" rod around the perimeter of the seat cushion to beef it up
Then sand blasted; the upholster had to tie wire some of the main springs together to replace the missing springs that hold everything together Pictures of the back will be posted as soon as I can | | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Thanks Lou, I believe we have the same Jim Carter cover, this is what I received;
UP148FS SEAT KIT 50-55 SPANISH GRAIN B 1.00 1.00 0.00 ROWN FRENCH STITCHING EACH French stitch, will also fit 1950-53. Original on 1954-
I see your cover has a white boarder/skirt to facilitate fastening it to the seat frame. Mind did not have this and I sure wish it did. My guess is your upholstery shop added this.
Looks good, and congratulations on how well your truck is coming along.
Ron
RonR
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jim Carter might still have his 47-55 seat upholstery colors incorrectly listed.
The solid brown was used 47-52. I think that solid maroon was used in 1953. Maroon sides and gray top seat-top/back panels were used in 54/55st.
JC also sells the same size covers for all A-D years, but, it seems the dimensions changed sometime during 47-55. JC's sizing was small on my 1954 spring-sets..
JC kindly let me contact his upholstery shop - she then made correct-size two-tone covers for me.
My guess is the same as Ron's regarding the white border most likely having been put on by Lou's upholstery installer. That border would not be needed if the original barrel clips were used, instead of more common hog rings (hog rings are easier to install AND MUCH easier to remove). | | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | All I confirmed my upholsterer did in fact ADD the white border for ease of install He also recommended letting Jim Carter know so they can make it easier for everyone | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jim Carter most likely would not want to carry both styles of covers:
- if someone is doing an original-parts install (with barrel clips), the white border is not needed and would have to cut off
- if someone is using non-original hog rings, the white border would be helpful/needed | | |
