2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Trying to figure out where my running board gaskets install. They are just over 3 feet long, 2" flat with a 1" lip. The area from the back of my front fender to the front of my back fender is just over 5 feet (I have the long bed). Where in this space does the gasket go? Up toward front fender or in the back? Or do I have the gasket for the 1/2 ton bed? However 3' does not seem long enough for a half ton either? My '38 running board is over 4 feet. Help, please. Thanks!!!! | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Not sure what you have, but this is the only style GASKET SET I know of. Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Thanks. Are those in your photo for where the front and back fenders meet the running board? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Maybe those are like the ones for a panel or suburban that fits between the cab and fender. I'm just guessing here without a picture.....but the flat part probably hangs down and the lip lays on top of the cab/body edge. Am I making any sense?
| | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Yes. I'll try to take a photo and post. Thanks. | | |
