6 members (greenie-reddy, FAST55, MRMEROTH11, Otto Skorzeny, 1955 1 Series, Hotrod Lincoln), 107 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1196620 12/23/2016 7:38 PM
To all Merry Christmas and a Happy New Year. I just dumped as chuck of change for 6 new 8R19.5 Samson china tires and looking for some advise to keep them from checking or cracking. I know to keep the tires out of direct sun light for long periods of time, and use them so they don't get flat spots. I'm looking for a product or solution that will not take the compounds out and dry the rubber out. I found some products make the tire look great then turn the tire into a junky, where you have to keep using the product or the sidewalls fade fast and crack fast i.e. ARMORALL. Thank you
Rich 1952 #1196623 12/23/2016 8:01 PM
check out mequiars products
Rich 1952 #1196625 12/23/2016 8:19 PM
Nitrogen baby, yeah!! yahoo Just kidding.
Would think any of the modern spray on products would be fine. I honestly don't know what to believe about minor sidewall cracking. Had a set of Michelins the sidewalls were cracking pretty bad and there was a recall at the time but not for my particular tires. So they lasted many tens of thousands of miles till I sold the car, no problems.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Rich 1952 #1197546 12/30/2016 5:32 PM
The very best and most effective thing you can do is minimize time in the sun. If the truck is going to be parked outside, put covers over them. If its going to be parked for a long time - put it on blocks to get the weight off the tires to keep them from flat spotting.
1950 4100 - unrestored and driven weekly for almost no reason at all.
Rich 1952 #1197552 12/30/2016 6:02 PM
Coker recommends simple green to clean tires.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Rich 1952 #1197738 12/31/2016 10:55 PM
Turn them often. Don't dress them with anything at the risk of drying them out as some products will do.
Tires deteriorate with time mostly and not running them seems to speed up the deterioration.
Don't just store them away for a few years and expect them to stay like new.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
