1 members (klhansen), 98 guests, and 0 robots.
Topics128,126
Posts1,056,356
Members48,441
#1196532 12/23/2016 3:18 AM
Allen
1974 Stingray Corvette
Very cool, thanks or the link...
'59 Apache
‘21 Beta 390RS
‘18 BMW R1200RT
'12 Ford Flex
'13 Aprilia Tuono
‘11 Ducati Hypermotard
Salisbury, MD
Quick- - - -they do it almost that fast between runs at a NHRA event!
So can some of you experts please explain what is taking place from 2:50 to 3:05.
Allen
About 2:50 looks like powder coating. Then they start the balancing procedure. The items clamped onto the crankshaft are called "bobweights" which simulate the weight of the pistons and connecting rods so weight can be added to or removed from the crank counterweights, like balancing a wheel/tire assembly.
Looked like paint then balance rotating assembly, removing some weight from a few rods with a belt sander.
•1952 Chevrolet 3800 pickup
---All pictures---
I usually static balance (weight match) all the moving parts such as rods, pistons, etc. (including wrist pins, rings and pin locks) to a tolerance of 1/10 gram before calculating the bob weights. A dollar bill weighs one gram.
2 questions guys...
If all the moving parts are matched, why wouldn't you just balance the crank without anything on it?
I love that home made intake. Not painting it shows the temp rings from welding. Do you think they just put regular old clear coat to get that shiny finish?
Allen
V8 cranks are not naturally balanced like an inline six. Without bobweights the crank would jump out of the balance machine.
