| | | Forums66 Topics128,087 Posts1,056,337 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I want to paint my hood springs. If I remove the spring from the bracket will I be able to put it back as before? I imagine that it would be a difficult task to coil it back to the proper position. Anyone tackle this before? | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I don't recall any difficulty or drama when I did mine. I recall it being fairly easy. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Not much of a problem. You'll need a stick to hold up the hood unless you have someone to help. Disconnect at the hood first. You'll have to move the hood up and down a bit to get the weight off the bolt. Be sure to note left side,right side. | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | You said "spring from the bracket", not the bracket assembly from the truck. I would not in anyway disassemble the spring from the whole assembly, that's asking for trouble. Just take the whole assembly off, sandblast, spray paint, and reinstall. No need to completely paint the inner surface of the coil. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I use a piece of 1 3/4 exhaust tubing split in half length wise with a washer that just fits the ID welded/brazed at each end. Open the hood just enough to reach arm through and snap tool into place in spring coil gaps and then raise hood to full open position. Springs usually fall onto floor. To paint, the spring is hooked one end to a socket extension clamped in the vise and the other end to a come-a-long which is hooked to the far end of the bench. Work come-a-long till spring has good gaps for painting and leave until paint has dried.
Evan
