0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | This may seem like a dumb Q for some of you but I don't recall seeing this at Wallyworld.  So where does one go to get this stuff? Anything else I need to know about which one to buy? There may be othere pertinent questions I'm not but should be asking so feel free to enlighten me. And thanks in advance.
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | All the Holmes Depots in my area carry the actual "Bondo" products. Well, I don't know if they have the hair stuff but, they've got the lighter skim coat stuff. Autozone has stuff as well. Couple different brands including Bondo. You might check out a local auto body/paint store. My local carries Evercoat. -David | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | You must have a lousy Wally-World. | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | there are alot of body fillers out there go to the local parts store they will have most of what you need..I like and use evercoat....doc | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Kmart carries both the fiberglass and plastic Bondo brand body fillers in our area. There are a lot of other brands out there, so check with your local auto parts store too. | | | | | Joined: Feb 2006 Posts: 20 Junior Member | | Junior Member Joined: Feb 2006 Posts: 20 | Never be afraid to ask a question, if you want to know, then there are probably 100's out there that want to ask. I was in the auto body field for 20 years before going to the fire service. Use a high qualty, "LITE" filler, it may be more expensive but worth the savings in sand paper, labour and frustration. Look in your local phone directory for Auto Body shop suppliers, they would have the best selection and in all reality the best advice. The hard part for people new to bodywork is to know when to stop sanding. Take your time, stop often to "feel" the work and keep the paper sharp. Follow the directions of the manufacturer. It's better to add more hardener then less, it has been proven that bleed through (spots in the paint in areas of filler)is the result of insufficent hardening. If you wish send a PM and i'll give you what info I have. Good luck
Allan S Langley B.C Canada
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Click here for the best filler there is, EverCoat. Give them an email and find out where the nearest distributor is. Pull out your phone book and look under "automobile paint supplies". Or go to a body shop in town and ask them where they get their supplies. There is a paint store in the area I am sure of it. They will have all the supplies with paint, plastic fillers (bondo)tools, etc. If all else fails, NAPA Auto parts stores distribute Evercoat products under the Martin Senour paint line. But give the phone book and or a shop a try. Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
