4 members (UtahYork, 55shaker, 3B, Otto Skorzeny), 78 guests, and 3 robots.
Topics128,031
Posts1,055,433
Members48,422
#1188995 10/31/2016 10:36 PM
I was just thinking about all the Chevrolet trucks (6 Cylinder 235) around and what improvements you have done to your truck that has improved its drivability , performance and looks, etc etc. I would love to hear from other owners.
I will start with my truck.
1954 Chevrolet Truck 3800 1 Ton Flat bed, owned since 1975
Things done to improve trucks performance
1.Fenton headers
2.Clifford intake manifold 6=8
3. Four barrel carburetor 390 4160
4.SoCal steering damper
5.Gear Vender overdrive GV-RX
6. Flowmaster mufflers (2) 40 (a little loud).
7.Convert 6 volt system to 12 volt (no need to change starter still 6V)
8.Moon electric tachometer 2 5/8 inch
This truck just hums down the road, very nice.
http://s1288.photobucket.com/user/richardO54/library/?sort=6&page=1
3800rao #1189006 11/01/2016 12:21 AM
I've swapped to 8R19.5 tires and suitable wheels.
And 4.10 axle gears.
Otherwise just been driving, it's happy at 50-55 but can handle the interstate for a stretch here and there at a brisker pace, and once had it over 70mph briefly under its own power.
1952 Chevrolet 3800 pickup
---All pictures---
3800rao #1189020 11/01/2016 1:27 AM
1 Offline
Complete build of "Dually" bed
Replace fuel pump, (old one quit)
Re-wire with Jim Carter Harness retaining 6 volt
Restore Gauges and Speedo
Replace 5:14 Pumpkin with 4:10's
Have new cab, door seals, ect to be installed this winter
Also hope to fabricate and install rear bumper
Drive and Enjoy!
3800rao #1191006 11/15/2016 6:25 PM
12 volt alternator
Radial tires
Front disc brakes
Juliano 3 point shoulder harness
Newer Chevy rear end with 4.10 gears
Large outside mirrors
Newport wiper conversion
Halogen headlights
Altman door latches
1951 Chevy 3800 1-Ton
Howard Knapp
3800rao #1191575 11/19/2016 7:29 PM
Installed a T 5 trans. which made the truck 100% more drive able , and as an experiment a coat of Home depot bear latex house paint semi gloss as close to the original as possible and even coated a section with automotive clear coat.
Its been 2 years and 6000 miles and its still hanging in , but easier to clean where the clear coat is.
I did the whole job for $75.00 including masking tape.
I used a typical spray gun for the job.
good planning is no substitute for dumb luck
3800rao #1191612 11/20/2016 12:53 AM
back yard wrench turner
12 volt alternator
disc brakes on the front
tapered roller bearings
16 inch 1 piece wheels
HID headlights
'56 GMC 270 with 3 speed trans
3.90 rear axle gear
bendix brakes on rear
fuel tank under the bed in rear
electric wiper
radial tires
turn signals
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
3800rao #1195977 12/19/2016 12:58 PM
Stovebolt Photo Moderator
1947 - dally 3800
When mine goes back together it will have the 4:10's and 8r19.5 rims with radials
12V. Alternator, probably an electric fan.
1962 full pressure 261, stock carb, intake and exhaust. SM-420
Fully rebuilt front end, sandblasted and painted frame
Cab will be "patina" farm fresh. New passenger floor panel and drivers cab corner.
Still figuring what to do for a wiring harness, wipers, oil filter and fuel pump
Goal: roll under its own power for Labor Day parade 2017
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
3800rao #1196120 12/20/2016 12:16 PM
1949 3800 flat bed
A complete rebuild (Still in progress)
Also blasted & painted the frame
I replaced the 217 with a 283
SM-465 4 speed with a hydraulic clutch
14 bolt rear diff, 3.93 gears
17" 1 piece steel rims
12 volt wiring harness
Alum Radiator with electric fan
Harrison Deluxe Heater
Dual Master cylinder with booster
L&R Inner & Outer Cowls, R/side floor panel and L/rear cab corner.
painted the interior & exterior
Every seal on the cab and doors
All the bed boards were planed from reclaimed red oak timbers.
Next adventure on it is to install hanging pedals and add a steering gear box.
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
panel fan #1196122 12/20/2016 12:44 PM
That T-5 sounds interesting. I would like to research bellhousing match and where the shifter protrudes from the floor. I imagine it would improve the driving experience. - Joe
3800rao #1196278 12/21/2016 5:01 AM
62401
'49 3804 here.
-- Upgraded to early 261
-- Stock SM420
-- Upgraded the rear axle to the 4.10 gear set
-- 17-inch wheels (bias plys)
-- Added seat belts
-- Original Huck brakes and they work just fine. I drive defensively so have not yet had to deal with a stab/panic brake situation.
-- Cruises 65 MPH, dashes to 70. Slow on acceleration, though. Easily cruises at 80 to 85 mph ... on the trailer smile
-- Not a daily driver. That's what the '88 Army-surplus Hoopty van is for wink And farm work gets done by the two Fjords ... eeeek
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
3800rao #1199378 01/12/2017 5:40 AM
1950 GMC 250 w/ duals and flatbed
Fairly new to this site and finding it a great resource.
In past 10 months
Replaced front axle with one that's not bent
Replaced king pins
Replaced front spring shackles and bolts
Replaced both front main springs.
Replaced front brake shoes
Replaced front wheel bearings and seals
Replaced rear wheel bearings and seals
Front end alignment
Replaced all four brake wheel cylinders
Removed worn out 228 and installed a 1955 270.
6V pos ground to 12 neg ground w/ alternator
Installed headlight relay
Replaced rt park brake cable
Welded up cracked inner fenders
Welded cab floor cracks
Replaced cab mounts
Cleaned all mouse crap out of cab
New cowl rubber and hood rubber bumpers
Currently this week:
Replacing 3 u joints
Replacing carrier bearing and bearing cushion
Next:
Rebuild master cylinder
Replace front fender supports
Replace battery tray bottom
Rebuild door hinges
Install three whiskey barrels on flatbed just cause i want to.
Drive the crap out of it after all this snow goes away.
Pete.
You can't run with the big dogs, if you pee like a puppy.
1950 GMC 253 1 Ton
1965 Sunbeam Alpine / 2.8L V6
06 Dodge/Cummins
3800rao #1199393 01/12/2017 2:49 PM
Offline
Offline
Gonna be a WHILE before that snow goes way!
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
3800rao #1202846 02/04/2017 5:25 AM
New carrier bearing and bearing cushion installed
Replaced all three u joints. Put it on jackstands are ran it to 50 mph. Vibration is significantly reduced, but not al the way gone. Suspect the slip joint. Good enough for now.
Rewired firewall forward. Much better/
Rebuilt master cylinder and bled brakes.
Waiting for the roads to clear of snow for a test drive.
Next. Off to the Portland swap meet in April in hopes to find at least one rear brake drum. Maybe even a metal frame for flat bed rebuilt.....hey, a guy has to dream, right?
Next winter...remove rear springs and have worn main springs rebuilt and new spring perch bushings installed. Fix leaky rear diff while it's down for the winter
EDIT. New battery tray installed.
This is fun.
Pete.
1950 GMC 253 1 Ton
06 Dodge/Cummins
The snow went away and roads cleared. Took Jimmy out for its first ride after a lot of work, including engine change, driveline work and front end work. Runs much stronger than before and wobbles are almost gone
Two troubles appeared. 1. It died one time at a very busy stop light....thankfully started right back up with a little choke.
2. I still have a vibration that starts about 25 MPH and goes away at 40. Much less intensity than before. Seems to be about driveshaft speed. That leaves a slipjoint suspect or driveshafts simply need to be balanced. Another day..
No Leaks!!!
It was good to have it on the road again.
Pete.
1950 GMC 253 1 Ton
06 Dodge/Cummins
Moderated by  Dusty53
