Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 133 guests, and 4 robots.
Topics128,283
Posts1,058,505
Members48,490
#1195535 12/16/2016 12:22 AM
Can anyone tell me where I can find a Chevrolet shop manual for body part identification and repair? Is anything available online?
What is rear half of left front fender skirt? Is this the two step body part?
This Factory Assembly Manual is supposedly for 1947-1954 trucks; however, it is actually for the 54/55st Chevrolet truck.
That manual takes some getting used to - in terms of finding your way around it. I do not have mine readily available - I do not know/recall how much COE front-fender/etc detail is in it. Maybe someone will check this out?
Hickey,
The COE fender skirt will be found under the fender. Best to dismount the wheel and you should see two panels separating the engine compartment from the wheel well. They are held by bolts with large fender washers. This will give you access to the carburator. Alternatively, you can remove the driver side floor board and work from both the top and underneath the truck. Either way it is a lot of fun!
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
LOL. I like that answer. Best to make it a tilt cab & forget about it... But that will spoil the fun. LOL
Darrell, W.L.
1939 Chevy COE tow truck/My Stubbed toe
1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation.
I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
