2 members (RLB, 51 3804),
126
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 10 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 10 | Can anyone tell me where I can find a Chevrolet shop manual for body part identification and repair? Is anything available online?
What is rear half of left front fender skirt? Is this the two step body part? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | This Factory Assembly Manual is supposedly for 1947-1954 trucks; however, it is actually for the 54/55st Chevrolet truck. That manual takes some getting used to - in terms of finding your way around it. I do not have mine readily available - I do not know/recall how much COE front-fender/etc detail is in it. Maybe someone will check this out? | | | | | Joined: Apr 2007 Posts: 1,044 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,044 | Hickey, The COE fender skirt will be found under the fender. Best to dismount the wheel and you should see two panels separating the engine compartment from the wheel well. They are held by bolts with large fender washers. This will give you access to the carburator. Alternatively, you can remove the driver side floor board and work from both the top and underneath the truck. Either way it is a lot of fun!
Kent | | | | | Joined: Oct 2008 Posts: 126 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 126 | LOL. I like that answer. Best to make it a tilt cab & forget about it... But that will spoil the fun. LOL
Darrell, W.L. 1939 Chevy COE tow truck/My Stubbed toe 1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation. I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
