3 members (46 Texaco, wilbur53, 1 invisible), 69 guests, and 5 robots.
Topics128,264
Posts1,058,357
Members48,485
#119512 02/11/2006 6:02 PM
What is the best to try and get a warp out of a Bed Side? I got it to hot while welding in patch panels and now have a big warp right above the center bolt hole of the fender.I don't have acess to a torch. Just wondering if I could heat it up with a small propane torch and quench with water, or would this make it worse?
#119513 02/11/2006 7:23 PM
Eric,
There are special sheet metal shrinking body hammers with textured heads available. If the warpage isn't too bad, that's what I would recommend using.
Good luck!
~ Kimberly
My '54 ... and my '63 and a '59 F100
#119514 02/11/2006 8:18 PM
We have used a special tip for the MIG welder torch with some success. It has been a while, but as I remember it is a carbon rod that makes electrical contact with the warped metal heating it up in a localized area, acting a bit like a soft gas welder flame. Maybe your MIG welder could be set up with that. Check with the welder supplier. Ours is a Lincoln Idealarc about 25 years old. It took a little practice but it works.
Mar-Ktech
