| | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | What is the best to try and get a warp out of a Bed Side? I got it to hot while welding in patch panels and now have a big warp right above the center bolt hole of the fender.I don't have acess to a torch. Just wondering if I could heat it up with a small propane torch and quench with water, or would this make it worse? | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Eric, There are special sheet metal shrinking body hammers with textured heads available. If the warpage isn't too bad, that's what I would recommend using.
Good luck! | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | We have used a special tip for the MIG welder torch with some success. It has been a while, but as I remember it is a carbon rod that makes electrical contact with the warped metal heating it up in a localized area, acting a bit like a soft gas welder flame. Maybe your MIG welder could be set up with that. Check with the welder supplier. Ours is a Lincoln Idealarc about 25 years old. It took a little practice but it works.
Mar-Ktech | | |
