| | | Forums66 Topics128,089 Posts1,056,117 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Lucy is do well but my bench seat will eventually need some work, my frame and springs need a quick coats of paint but the material is starting to have a few splits in it, I saw Jim Carter has a reapolstering kit and new material ready to put on the springs, has anyone ever used this kit? Is it somthing that will last? | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I bought one of their kits earlier this year. I installed it and didn't like the way the corners fit. There were wrinkles and puckers at the corners. I then took it to an auto upholstery shop. They had to do some minor alterations to get it to fit tight and look right. I thought initially the cause might be the springs and/or foam were the problem, but they said they looked and felt fine. The previous owner had redone the seat cushions, but they were never used. Unfortunately, he had used a light cream color material that is incorrect for my preferred restoration.
