2 members (J Lucas, HandyAndy), 56 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
#1193846 12/04/2016 11:00 PM
I
I Offline
Lucy is do well but my bench seat will eventually need some work, my frame and springs need a quick coats of paint but the material is starting to have a few splits in it, I saw Jim Carter has a reapolstering kit and new material ready to put on the springs, has anyone ever used this kit? Is it somthing that will last?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
I bought one of their kits earlier this year. I installed it and didn't like the way the corners fit. There were wrinkles and puckers at the corners. I then took it to an auto upholstery shop. They had to do some minor alterations to get it to fit tight and look right. I thought initially the cause might be the springs and/or foam were the problem, but they said they looked and felt fine. The previous owner had redone the seat cushions, but they were never used. Unfortunately, he had used a light cream color material that is incorrect for my preferred restoration.
Moderated by  ndkid275, Phak1
