| | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Lou,
Did you first unscrew the end-cap and slide it back?
Also, the outer surface of the torque-tube should be shiney-slick (no paint and no rust) for as far back as you have to slide the bell/cover.
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Tim, as for the bell cover with 4 bolts yes; I am assuming the end collar on the opposite of the end that slides down is all one piece? The torque tube does have dirt and gunk that I didn't clean off | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Lou, on the right end of the ball/bell/housing is a collar that is screwed onto the threaded right-end of the bell/ball/housing. Inside that collar is a seal and two metal rings. That collar can be unscrewed and pushed rearward - this make it easier to move the ball rearward. The outer surface of the torque-tube needs to be clean, shiney, and smooth. | | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Sorry for late response Got it!  | | |
