1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
Hello all
First time experience removing the tranny for a clutch job
Does everyone have issues sliding down the torque tube bell?
Any advice is appreciated
http://i430.photobucket.com/albums/...9BF5CA0D-000F-4631-AA38-CE9C78DEBA4A.jpg
1949 Chevrolet 3100 Suburban Carryall
"Bad Guy"
More pix in Photobucket
1950 Chevrolet 3100 3-Window
More pix on Photobucket
1966 GMC Suburban Carryall Custom
"Big Guy"
Lou,
Did you first unscrew the end-cap and slide it back?
Also, the outer surface of the torque-tube should be shiney-slick (no paint and no rust) for as far back as you have to slide the bell/cover.
Tim, as for the bell cover with 4 bolts yes; I am assuming the end collar on the opposite of the end that slides down is all one piece? The torque tube does have dirt and gunk that I didn't clean off
"Bad Guy"
"Big Guy"
Lou,
on the right end of the ball/bell/housing is a collar that is screwed onto the threaded right-end of the bell/ball/housing.
Inside that collar is a seal and two metal rings. That collar can be unscrewed and pushed rearward - this make it easier to move the ball rearward. The outer surface of the torque-tube needs to be clean, shiney, and smooth.
Sorry for late response
Got it! smile
"Bad Guy"
"Big Guy"
