8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible), 72 guests, and 1 robot.
Topics128,140
Posts1,056,770
Members48,454
Set my timing and got the 216 cu.in. running GREAT, but it appears the distributor grease cup is hitting the vacuum advance assembly when I rev up the engine. How much rotational movement on the distributor when vacuum advance takes over when revving the engine? How do I correct this so the grease cup sets at the six o'clock position and the cap clips are horizontal to the engine block? Right now the cap clips are at the 8 o'clock and 2 o'clock position.
Tim
1970 VW Beetle
H Online: Content
Move the drive gear engagement one tooth clockwise and re-time the distributor. That will change the relationship between the grease cup and the vacuum chamber.
Is it possible to set to TDC on the BB, loosen the distributor clamp and rotate it so that the distributor cap clamps are horizontal with the engine block and then re-index the plug wires?
1970 VW Beetle
Yes
Any special procedure?
1970 VW Beetle
Make sure that #1 is at TDC of compression stroke. The BB by itself only gives you a 50/50 chance of being correct.
1951 3100
H Online: Content
Either BB position works. Just align the BB, turn the housing one position clockwise on the distributor cap/rotor relationship and walk the wires back, then reset the timing.
Thanks Tim and Jerry. Think I can handle it from there. Seems as I get older, I forget more and more what use to come as second nature...
Tim
1970 VW Beetle
