1 members (klhansen),
136
10
Mod | | | Forums66 Topics128,281 Posts1,058,470 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Set my timing and got the 216 cu.in. running GREAT, but it appears the distributor grease cup is hitting the vacuum advance assembly when I rev up the engine. How much rotational movement on the distributor when vacuum advance takes over when revving the engine? How do I correct this so the grease cup sets at the six o'clock position and the cap clips are horizontal to the engine block? Right now the cap clips are at the 8 o'clock and 2 o'clock position.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Move the drive gear engagement one tooth clockwise and re-time the distributor. That will change the relationship between the grease cup and the vacuum chamber. Jerry
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Is it possible to set to TDC on the BB, loosen the distributor clamp and rotate it so that the distributor cap clamps are horizontal with the engine block and then re-index the plug wires?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Is it possible to set to TDC on the BB, loosen the distributor clamp and rotate it so that the distributor cap clamps are horizontal with the engine block and then re-index the plug wires? Yes | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 |
| | | | | Joined: Jan 2014 Posts: 3,691 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,691 | Make sure that #1 is at TDC of compression stroke. The BB by itself only gives you a 50/50 chance of being correct.
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Either BB position works. Just align the BB, turn the housing one position clockwise on the distributor cap/rotor relationship and walk the wires back, then reset the timing. Jerry
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Thanks Tim and Jerry. Think I can handle it from there. Seems as I get older, I forget more and more what use to come as second nature...
Tim
