2 members (Frank50, Kilted54),
71
Mod | | | Forums66 Topics128,189 Posts1,057,222 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 45 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 45 | OK Guys, here is my dilemma. I currently have a 1948 3600 with a 1970ish 250-6. Fenton split headers and glass pacs running all the way out the back. I have been running this set up for about 6 years. I use a wireless bluetooth speaker to run some tunes and have to run full volume to really enjoy the music over running about 2500 rpms with the windows up. Would quieter mufflers make a discernible difference? It is really tough to tell if the overall noise is from the exhaust, or other road noise. I do have some bubble/foil type insulation under the rubber mat, also running up to just below the back glass, behind the door covers and under the headliner.
What say y'all. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Quite mufflers help. Had to replace exhaust system/pipes on my 52 once, thought the old muffler was OK, original design/shape muffler. The new one looked about the same as the old but was much quieter in the cab, it was nice. | | | | | Joined: Sep 2010 Posts: 2,334 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,334 | I thought those mufflers were designed to be quiet at first and then once the insides burn out they are quite loud .like the old thrush mufflers pass the noise laws but once used for a while they are like straight pipe. Real mufflers should keep things quiet.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..and a lot of it depends on where your exhaust pipe is pointing. Is it in front of the tire, coming out behind the tire, or straight out the back?? It all plays a part. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have generic glaspacs on my Suburban with Fentons. They were installed close to the front with a bunch of open pipe to the back. They were obnoxious. I installed a pair of Walker resonators close to the rear. It still has that mellow glaspac sound running through the gears but once I get into high it is relatively quiet. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Cletis, was/is your glas-paks a one piece steel tubing blown to shape as if a glass blower had done it with one piece? Or is it sheet metal on the outside? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | I have a mild 350 and was thinking about running a pair of stock style 216/235 mufflers. Anyone out there done this? I can't hear my 235 running at all at idle with this muffler, and exhaust note is pretty quiet when going down the road. I was hoping for similar results with dual exhaust using the same mufflers.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The 350 in my '56 is relatively quiet using the same generic glaspacs I have on the '54. Something about the V8 makes the exhaust notes smoother than the split manifold six. | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | The 350 in my '56 is relatively quiet using the same generic glaspacs I have on the '54. Something about the V8 makes the exhaust notes smoother than the split manifold six. I would guess that some noise cancellation is going on in the collectors of each side of V8 which cannot be duplicated with the Stovebolt 6 due to the shared exhaust ports of the 2-3 and the 4-6 cylinders which limits how one can split the manifold. If you have the opportunity of hearing a V8 with pipes coming straight out of each exhaust port at wide open throttle, you will find it just as annoying (or awesome, depending on your personal taste) as a split Stovebolt exhaust. BTW, thanks for sharing your satisfaction with straight through glasspacs. It gives me the confidence to go with the stock straight through mufflers on my 350. Carl
