1 members (Cletus1950),
77
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | I'm fitting my splash aprons and running boards to the fender/bed, how close should the splash apron fit to the bottom of the bed side? I think there should be a 1/4" gap or so to prevent rubbing? I bolted them to the rear fender and running board with that amount of gap but when I try to bolt on the long bracket for the splash apron to running board, it will pull it down to have something like a 2" gap or more.
Is there something I'm missing? It seems if the splash apron is bolted to the rear fender with the tab and it has a good amount of small gap (about 1/4") the bracket should fit to the running board also?
'53 Chevy truck 1/2 ton
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | kevmor99,
I am guessing you are talking about the splash aprons on the side of your truck in front of the rear fenders and behind the cab? Those aprons should bolt directly to the bed sides and running boards. The support brackets do fit to the splash aprons and running boards. You may have to adjust the brackets and aprons to fit properly. I had to do some minor flexing and bending to get my splash aprons to fit on my '49 3100. I placed some 1/4" diameter stainless steel washers between the running boards and splash aprons more to prevent water from hanging in between the running boards and bottom of the splash aprons. After flexing and bending I was able to get the aprons to fit just where I wanted them. You may have to loosen the running boards a little also and a second set of hands will help a lot. Hope this helps.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | Make sure that you have the proper 2 1/4 inch blocks between the front of the bed and the frame.
