1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 50 | Did a search on this topic and found a lot of info but couldn't find an answer to my question. I have a 51 3100 and a 53 side mount spare carrier. I have a dimpled fender. Trying to fit it up to my new bed and can see that the carrier has to go all the way up so the angled flange of the carrier meets the angled bedside. It would seem that I also have to mount it directly against the stake pocket also as it comes pretty close to a fender mounting hole. Also I understand the bottom two holes in the carrier take the reinforcement bar. Does that bar stay on the outside or the inside of the bed? Is the carrier supposed to be as flush up against the stake pocket as I can get it? This would mount the left side of the carrier directly on the pocket flange? :confused:
1951 Chevy 3100 5-window 261 cu in, 348 Head, Split Fenton Exhaust Offy with Dual Weber 2 Bbl Carbs
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | '51's didn't come with a side mount. Spare went under the bed. You shouldn't have the dimpled fender, so its hard to say what your looking at. The person who had it before you made some changes that weren't stock. Hopefully someone on the forum has gone thru what your doing and will have an answer for you. Cecil........ | | | | | Joined: Dec 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 50 | Actually, I am doing this to my 51. I know they weren't stock on my year. I guess I'm looking for someone with a 53 and a side mount spare. Same Bed, Same Fenders. And I'll ask another question or two. Does anyone have a copy of this RPO Drawing for 1953? I have 54 and 55 but they were different beds. I'm interested in seeing if it was a different mount for 6.00 and 6.50 tires.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | go for it bowtie . . . . your name is on the title I mounted my spare under the rear w/ a cable crank down set-up out of a new chevy truck. as well as a new under the bed tank, which was stock for 48 NBD have fun
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Dec 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 50 | Yeah Jim. I have a stellar under bed spare carrier but I moved the gas tank out of the cab and have a custom stainless tank mounted on the back end so there goes the stock mount. I like the look of the side mount so it should be no big deal to make it look like a 53 with the RPO. Just don't want to drill into a new bed without knowing.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Hey Bowtie, Caroline really wanted the side mount, but I told her if she ever had to change a tire the mounting woould be fairly high up and lifting that much weight would not be good on her back. We don't have a dimpled fender so the tire would be high. SHE still wants the side mount.......... My universal tank is under the pass side w/ the filler just in front of the rear tire fender. I used the old filler and rotated it 180 degrees and mocked it to a 2'' tube. holds 16 gal. let me or keep us all informed as to the side tire mounts, cause I have a feeling I'll need them.
