2 members (Hotrod Lincoln, UtahYork), 128 guests, and 3 robots.
Topics128,196
Posts1,057,388
Members48,471
Moderated
Moderated
Hello All!
I've just recently purchase a 51 Chev 1434 (3800). I've been reading through this site for a while, and it's been a huge wealth of knowledge. This is my first old vehicle, and it's lived my lifetime twice.
My goal with this truck is to leave it reasonably stock, and just use it as it would have been used and maintained in the 50's. There's a lot of work to be done to get it road worthy and inspected so I can register it and take it on the road! (It's not going to be easy to get an old truck like this Safetied!)
I bought the truck a month ago, not running. Although it had ran a year ago. I'm a self proclaimed backyard mechanic, so it's nice to have a truck where there's no computers involved.
When I got the truck, I couldn't get it to even try to fire, so I started with some ignition work, I put in a new 6v coil, and tuned up the distributor with a cap/rotor, points, and condenser. After that, it almost wanted to start, but the 6 volt system just wasn't enough. I boosted the starter (starter only) with 12 volts, and after a few minutes of work, I got her running. It will now start under it's own 6v power.
The radiator leaks somewhere in the fins, just below the cap/neck, so I'll either have to try and get it repaired at a rad shop, or buy some that I've seen on ebay. None of the local shops can locate one.
The next thing that needed attention was brakes. The previous owner started by replacing or rebuilding the master cylinder, but hadn't dealt with the leaky brake cylinders. He included 2 rebuilt front brake cylinders, which I just put on the other day, but then I realized the back ones are leaking bad too. So the back cylinders are on order now.
After brakes are done. I need to work on the front suspension/steering. When I was working on the front brakes, the play in the kingpin area was very alarming. So I'm reading up on the replacement on that, and the tie rods, etc. I just need to figure out if I need the "oversize" kit or not, and which part#'s to order!!
After that, the wiring needs some major love. Electrically, I think all that works is the heater blower, the horn, and windshield wipers. None of the marker lights turn on, and there are no tail lights.
The major trick is going to be figuring out what parts are interchangeable from the 3100, and which parts are specific to the 1 ton.
Anyways, lets see if I can attach some photos of it being picked up, and it in it's new home.
I hope to be able to get this thing back on the road in the next couple of years. If there's anyone in Alberta with a similar truck, I would love to be able to pick your brain about locating parts, and some other info.
Paul
On it's way home
Its new home
A video of it finally running again
1951 Chevrolet 1434 (3800)
Paul, welcome to the Stovebolt. Sounds like you have a good handle on whats taking place with our truck. We are ALL here to help so ask questions in the most appropriate forums and let us help you.
Be sure to check out the tech tips and note the vendors. A lot of stuff does interchange so ask questions and let us help.
...I couldn't get link to work for some reason. Probably on my end??
Don't know we're in Alberta you are in but if you are close to the border rock auto does have some parts as well as other U.S. sites I am 20 min from the border in ontario and we have a border store that will allow parcels shipped to them and I can drive 20 min and pickup for 3 bucks pay my duty and sometimes it is worth the exchange in the currency.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Moderated
Moderated
I'll have to upload the pics to photo bucket. I wasn't sure if the link from Facebook would work.
Kevinski, thanks for the info. I'm around Red Deer, so a few hours from the border. I found out about rock auto this morning, and it appears they will ship to me, with ok shipping prices. Unfortunately I found the site after I ordered my brake cylinders from a local napa. I coulda saved $100 if I ordered from rock auto, even with the exchange and shipping...depending on duty.
Hello Paul
Its the brokerage fees and taxes that will up your shipping costs quite a bit when using couriers. Try to get small items mailed when possible. Like Kevinski said, I use an outlet in Port Huron to pick up packages.
I find trying to find parts on this side of the boarder to be a painful experience. I just bought shocks from the US for my 57 Olds for $22 each when Carquest wanted $49 each. Most times the guy behind the counter has no way of looking up the part let alone get it.
Good luck with your build.
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
Leo Offline
Moderator
Moderator
Welcome Paul, little by little, that truck will come back to life. Good luck.
Leo
Howdy Paul. Welcome to Stovebolt Forum
We Albertans have more members all the time. There are at least two one ton pick-up owners not too far north of you. I met one at the Reynolds History Road last June when we were up with our 55-4300 flat deck.
As said Rock Auto if they will mail something is a good way to go. Got a alternator in five days far cheaper than a local shop.
Good suppliers support this forum, use them if you can.
We are in California for the winter and I like The Filling Station in Oregon.
The Gov. requires a out of province inspection for anything not registered in ten years.Take your time to repair or replace parts and get everything working properly. Once you apply for the OOP inspection you have 45 days to get it to pass. Crappy tire can do it!
We will be home for Christmas and feel like a parts mule for a few guys that need things. I myself bought a plasma cutter & TIG welder. Keep in touch if you need something in the spring.
Howie & Valerie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
welcome from Tx
Redryder pix
My Hotrod
Welcome! shake And I'm sure you'll get "addicted"! grin
Originally Posted by Howies551Ton
We Albertans have more members all the time. (Gleichen/CalgaryAlberta)
Nice to see more Albertans coming around! smile
Big Bolt Forum Moderator
welcome to the site! While you are going through your brakes, don't forget to replace all the steel and rubber lines as well. Brake fluid is a water magnet and your steel lines will rust from the inside out!
Mike
Paul,
welcome to the Stovebolt. Your truck sounds very similar to mine. Mine is a Canadian GMC. I have a lot of fun driving mine. It has good road manners and I will never be fined for doing a burnout!
1951 1 Ton Completed
Hi Paul, welcome to the site from Spruce Grove!
I have had really good service and also a great source of parts from KMS Tools as well as The Old Car Centre in B.C.The front brake cyls came off the shelf from Lordco. I have bought some parts from a supplier in Ponoka.
As Howie said there are a couple of the 1 tons around and being readied for touring, helping everyone is be the motto for this site.
Doyle
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
