1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
#1190211 11/08/2016 10:08 PM
SiG
Offline
Did Chevrolet ever have an 8 lug 15" split rim on a 1949 Chevy Truck? I still have the old 8 lug split rims with new 235/75 15 tires. Do I have a 16" or 15" split rim, I just bought these tires and want to go with the Dexstar rims that fit my truck.
Big Bolt Forum Moderator
Your post is a bit unclear to me. If you have 235/75-15 tires that you want to use, you need 15" wheels. If they are are on your split rims now, then your split rims are 15".
Mike
SiG
Offline
I'm on these split rims now and my tire size is 235/75 15, I thought all the split rims for these trucks were 16"
Sir Searchalot
Sir Searchalot
There are "trailer rims" that are split and 15", 6 lug on 5 1/2.
I have some. They have the hub cap clips.
I have never seen a 15" split 8 lug, yet.
By split, you mean two piece with a ring, and by 8 lug you mean 8 lugs? smile
A 15" tire only fits a 15" rim.
I have seen a very original '56 3600 truck with 15" 8 lug rims.
I've seen them, too. 3/4 ton would be the only application I'm aware of for the 15" split rim.
Bill Burmeister
Sir Searchalot
Sir Searchalot
Good info. Now I know from the experts. Maybe the one's I have are worth something.
On the 55 1st series 3/4 ton the standard equipment was 15inch 6ply rated at 1500 pounds each capacity. Optional was a 7.50-17inch 2100 pound rated for single rear axle. 6.50-16inch was listed as an option for front and duel rear 3603 only. I don't know if that was the same for the earlier, but I have always seen the 15inch listed as the standard sized wheel on Advance design 3600s.
I have the solid single lock ring on my 15 inch - 8 lug rims on my 51 3/4 ton GMC
I owned an original 66 C-20 that came with 15" split rims. I believe that 16" split rims were available for that series also.
Fred
Z
hmmm.
hmmm.
Z Offline
I have 8 lug 15 inch lock ring wheels. In fact, today I got new tires mounted on the wheels today. Almost nobody does lock ring, I am thrilled.
