11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 49 | Did Chevrolet ever have an 8 lug 15" split rim on a 1949 Chevy Truck? I still have the old 8 lug split rims with new 235/75 15 tires. Do I have a 16" or 15" split rim, I just bought these tires and want to go with the Dexstar rims that fit my truck. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Your post is a bit unclear to me. If you have 235/75-15 tires that you want to use, you need 15" wheels. If they are are on your split rims now, then your split rims are 15". | | | | | Joined: Jul 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 49 | I'm on these split rims now and my tire size is 235/75 15, I thought all the split rims for these trucks were 16" | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There are "trailer rims" that are split and 15", 6 lug on 5 1/2. I have some. They have the hub cap clips. I have never seen a 15" split 8 lug, yet. By split, you mean two piece with a ring, and by 8 lug you mean 8 lugs? A 15" tire only fits a 15" rim.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | I have seen a very original '56 3600 truck with 15" 8 lug rims.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have seen a very original '56 3600 truck with 15" 8 lug rims. I've seen them, too. 3/4 ton would be the only application I'm aware of for the 15" split rim.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Good info. Now I know from the experts. Maybe the one's I have are worth something.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2016 Posts: 20 New Guy | | New Guy Joined: Sep 2016 Posts: 20 | On the 55 1st series 3/4 ton the standard equipment was 15inch 6ply rated at 1500 pounds each capacity. Optional was a 7.50-17inch 2100 pound rated for single rear axle. 6.50-16inch was listed as an option for front and duel rear 3603 only. I don't know if that was the same for the earlier, but I have always seen the 15inch listed as the standard sized wheel on Advance design 3600s. | | | | | Joined: Sep 2016 Posts: 17 New Guy | | New Guy Joined: Sep 2016 Posts: 17 | I have the solid single lock ring on my 15 inch - 8 lug rims on my 51 3/4 ton GMC | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I owned an original 66 C-20 that came with 15" split rims. I believe that 16" split rims were available for that series also. Fred
| | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | I have 8 lug 15 inch lock ring wheels. In fact, today I got new tires mounted on the wheels today. Almost nobody does lock ring, I am thrilled.
